Old 05-23-2016, 06:43 PM   #11
Name:	ImageUploadedByForest River Forums1464046941.386309.jpg
ID:	108781Click image for larger version
Name:	ImageUploadedByForest River Forums1464046958.455844.jpg
Ok, I'll just flip those valves up and cross my fingers.....
Melvinson404 is offline   Reply With Quote
Old 05-23-2016, 06:46 PM   #12
Score!!!!!!!!! You guys rock!!!!! Thanks. You saved me an hour and a half trip to the dealer......
Old 05-23-2016, 07:48 PM   #13
toolman_57
Do yourself a favor while you're in there. If you look next to the valves you'll see a couple of filter screen cups. Make sure the cups are tight or your pumps will cycle on and off to maintain pressure. Don't ask how I know.
toolman_57 is offline   Reply With Quote
Old 05-24-2016, 05:25 PM   #14
ARLO
Check all the fittings between the tank and the pump. If one is loose and sucking air you will never draw vacuum because it will suck up the air instead of the water.
rlocicero is offline   Reply With Quote
fresh water, tank, water, water tank
