Old 05-23-2016, 03:06 PM   #1
Help- No water from fresh water tank
2016 364TS. My fresh water tank is full with both water pumps on but no water coming from faucets (water works fine on city water). Dealer says let water pumps run for 5 min with faucets open. This isn't working. Is there any other answer other than my pumps aren't working?
Melvinson404 is offline   Reply With Quote
Old 05-23-2016, 06:05 PM   #2
tilap's Avatar
Can you hear the pump?
Denis, Forest river Georgetown XL 377 2015, towing a 2014 Ford Explorer XL
tilap is offline   Reply With Quote
Old 05-23-2016, 06:07 PM   #3
Who Dares, Wins
doc73's Avatar
IF you can hear the pump it could take awhile to fill the lines if there is not water in them and the water heater was empty.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 05-23-2016, 06:10 PM   #4
nomad297's Avatar
Flip the valve from winterize to fresh water uptake.
Bruce
nomad297 is online now   Reply With Quote
Old 05-23-2016, 06:24 PM   #5
Iggy's Avatar
Bruce
X2
Old 05-23-2016, 06:25 PM   #6
Yes I can hear the pumps. Nomad, where is the valve you are referring to?
Old 05-23-2016, 06:26 PM   #7
toolman_57
Bruce
In the 364, that would be 2 valves. They're in the drop-down bin under the bunkhouse slider behind a plastic panel. You can either go through the portholes or remove the panel. I just pulled the panel and stuck it on top of the tank. Much easier to check the water level.
toolman_57 is offline   Reply With Quote
Old 05-23-2016, 06:28 PM   #8
Ok these valves? Do they appear to be in correct position?
Name:	ImageUploadedByForest River Forums1464046094.446207.jpg
Old 05-23-2016, 06:33 PM   #9
Nope those are your water heater bypass valves, but they are all set correctly.
2016 Flagstaff 23lb
Toddupton is offline   Reply With Quote
Old 05-23-2016, 06:39 PM   #10
Flybob's Avatar
The winterizing valve may still be in the antifreeze intake position if this is the first time you used the RV since being winterized.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
fresh water, tank, water, water tank
