Old 12-16-2013, 09:25 PM   #11
bend302's Avatar
I am not familiar with the charge line but we have a friend with a 2012 CRV that removes 2 fuses while towing. She was removing just one and the battery was down after just a few hours. A dealer told her about the other one and now all is well. But, I doubt she has a charge line..
I believe one prevents the odometer from registering towed miles.
Bill
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
bend302 is offline   Reply With Quote
Old 12-16-2013, 09:58 PM   #12
Krazymace's Avatar
I checked the specs on CRV's. No fuses need to be pulled.
Krazymace is offline   Reply With Quote
Old 12-16-2013, 10:59 PM   #13
HONDAMAN174's Avatar
Usually, there is a 7.5 amp fuse that gets pulled that kills power to the radio- even if the radio is not on. I will try to look in the service manual in the a.m. Only other thing I can think of is if a brake buddy is left in/on.
Just glad to get away
Old 12-16-2013, 11:06 PM   #14
Krazymace's Avatar
If you plug brake buddy into cigarette lighter, it will drain the battery.
Old 12-17-2013, 12:27 PM   #15
kenandterry's Avatar
Rstoro........
From your original posting you said.........
we have a 2010 Georgetown 350 and tow a 2012 Honda CRV, we had a trickle charger installed to alleviate the battery dying on us, but the last few times we have towed about 8 hours we arrive at our destination disconnect the toad from the coach and in the am the battery on the car is dead, any ideas??
1. The trickle charger.......is this to plug into AC outlet? What good would this do for towing?
2. Does the trickle charger work somehow from power of the GT350?
3. You mention disconnecting from the coach. Is the car battery okay when you do this?
4. Do you disconnect every night? If so why?
5. If battery is dead in the am, I submit it must have been close to dead at night, and if not, there is SOMETHING still on, and draining the car battery.
6. Does the car battery give you any trouble when NOT associated with towing behind the motorhome any other time?
Just wondering
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 12-17-2013, 12:43 PM   #16
10x
Sounds like you have a draw. Does the Honda have a automatic transmission? If so, you probably have key on to keep tranny in neutral while towing. Quickest fix is to disconnect negative battery on the Honda while towing. Forget the fuses, you need a magnifying glass to see them. You will need a 10mm wrench to disconnect cable.
2014 XLR 27 HFS
2010 F250 4x4 Crewcab Turbo Diesel
10x is offline   Reply With Quote
Old 12-18-2013, 10:41 PM   #17
I too have a SMI stay and play brake controller on our 2008 Honda CRV with a Brake Buddy #39332 battery maintainer. Our motorhome is a Georgetown XL 378. My Brake Buddy battery maintainer works great. Only 20 bucks on Amazon.com
I suggest to make sure the battery maintainer is supplying 13.7 volts to the Honda while the motorhome is running. If it is and you disconnect the toad at night then your crv is either draining the battery or the battery is going bad. Try disconnecting the battery at night and see if it is good in the morning. If it is it might indicate a small drain in the cvr. Also you can take the battery to a local auto parts store and they will put it on a load tester for free. (Call first to make sure they have one)
Good luck
2013 Georgetown XL 378
2008 Honda CR-V
wrapperman is offline   Reply With Quote
Old 12-19-2013, 10:18 AM   #18
I put a knife switch on my toad battery to disconnect all power to the toad. For my brake buddy, we ran one of the trailer hitch pin wires into the toad for the 12 volt power that is now provided by the RV.
Bob & Sue Rowan
Okeechobee, FL
2012 Coachmen Mirada 29DS (SOLD)
2015 Keystone Bullet Travel Trailer
2016 F-150 Lariat with Auto Trailer Backup
Dog = Morki (Yorkie-Maltese) - Zoe
Malabarbob is offline   Reply With Quote
Old 12-19-2013, 11:51 AM   #19
I have. 2006 CRV toad for my 2013 351. I have the charger and use a brake buddy. I had problems with the battery at first, then realized I was not pushing the plug from the 7 pin in all the way. It has to be jammed in there. Haven't had a problem since, and have put a good 5K miles on.
mdimarti is offline   Reply With Quote
toad
