Old 12-16-2013, 10:06 AM   #1
help with honda crv toad?
we have a 2010 Georgetown 350 and tow a 2012 Honda CRV, we had a trickle charger installed to alleviate the battery dying on us, but the last few times we have towed about 8 hours we arrive at our destination disconnect the toad from the coach and in the am the battery on the car is dead, any ideas??
R & S
rstoro is offline   Reply With Quote
Old 12-16-2013, 11:03 AM   #2
MC9
Sounds like you left it on "accessories" when you unhooked. I leave mine in the garage for six months at a crack.
MC9 is offline   Reply With Quote
Old 12-16-2013, 12:46 PM   #3
HONDAMAN174's Avatar
Yep. Sounds right.
Just glad to get away
Old 12-16-2013, 01:09 PM   #4
pretty sure when we unhooked we shut the car off and took the key out??
Old 12-16-2013, 02:39 PM   #5
bend302's Avatar
Do you have a braking system installed?
What fuses do you pull to tow?
Bill
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
bend302 is offline   Reply With Quote
Old 12-16-2013, 03:03 PM   #6
Iggy's Avatar
R & S
Have ever tested the car battery with a volt meter while the motorhome is running to see if you are really charging your battery while driving?
Your battery voltage should be 13.7 volts if you are using the MH charging circuit. You do have to make modify that circuit to charge your car battery while driving.
Old 12-16-2013, 05:08 PM   #7
fyi we have a SMI braking system, and we do not ? pull any fuses, we thought that was the purpose of the trickle charger to avoid that???
Old 12-16-2013, 05:31 PM   #8
rskrbina's Avatar
Agree with the earlier posts that some accessory is left on in the honda after disconnecting. You may have to measure for amp draw at the battery. Anything higher than 50 mh means something is "On".
Rudy and Jenny
2014 Flagstaff V-Lite 28WRBS
2013 F-150 Eco-boost 3.55
rskrbina is offline   Reply With Quote
Old 12-16-2013, 06:58 PM   #9
will it help maintain the battery charge if we keep the car connected to the motorhome while we hookup to campground electric??
Old 12-16-2013, 09:07 PM   #10
Send a message via Skype™ to Falcon35
We have a charge line on ours and one night I forgot to turn the key off on the toad.
The battery was to flat to start the car. So I think when the ignition key is off the power to the charge line is off. Could you ask the person that did the hook up for you. Or you use a tester to see if there is power on that line with the key turned off.
2012 Georgetown 378TS Fire Mist
2008 Honda Fit
ReadyBrake™ Surge Brake System integrated with ReadyBrute™ Elite RV Tow Bar
Protect-A-Tow
Falcon35 is offline   Reply With Quote
toad
