Originally Posted by SurferDude
- New 2012 Georgetown 351DS -
When I use the Fresh Water tank I have hot water but when I hookup to city water than both hot and cold valves have only cold water coming out. This is the case for Shower, both sinks and outside shower. (I did not touch any of the bypass valves and the dealer only demonstrated hot water without hooking up to city water.)
Please advice
Michael
Michael welcome.
If you are getting hot water when using your water tank then you should get when hooked up to city water.
The hot water heater gets input water from both from a T fitting and no valves.
Can you explain how you got hot water the first time?
Were you using propane or electric for the hot water.
If you tried the second time maybe you are out of propane?
Have you checked the tank and guage?
Is your propane leak detector have a green light or something else?
Did you have your master battery power disconnected?
See diagram
Let us know a little more and maybe we can help.
Iggy
