Old 08-09-2011, 08:25 AM   #1
Hi question about front side window leak
On a 08 370TS noted what appeared to be a water leak near left front side window -- now window has fogged up appears double pane type. Looking for real world from you folks on probable cause (if its typical ) and cheapest fix before asking dealer for options. Havent used teh rig a lot but that is now going to change with semi retirement working when i want
Thanx all Miami - Lakeland Fl
MIke1625 is offline   Reply With Quote
Old 08-12-2011, 12:30 PM   #2
It appears the seal holding the air between the double pane windows may have been broken and that is why the window is fogging...My experiance with these is not to mess with repair of the seal because it usually never works well...I had one just like yours and replacement of the window was the best option and make sure the installer seals the frame around the opening properly.
polkatronron is offline   Reply With Quote
Old 08-17-2011, 07:02 AM   #3
Is there a leak on the inside of the coach left side?
louis cherry is offline   Reply With Quote
