Finally had a mobile technician come and check out our high pitch sound issue. We tested all of the battery connections, everything at 13.7.
After looking more, the sound was coming from the other side of the coach. Yes, it was the ProWatt inverter, located above the propane tank. We removed the water cover and found that the inverter was not fastened down when manufactured. The inverter bounced around and was upside down. Removed it and the noise went away, but the smell from the inverter was like burnt plastic.
Bottom line, it was toast. Did not work when turned on. This has been an issue for us since we purchased the coach. Never had the refrigerator on while in transit because the inverter never worked.
Replaced, and Forest River Warranty Manager Nicholas Hoover is great! Very responsive and helpful. His email is
nhoover@forestriverinc.com
