Old 07-11-2014, 04:30 PM   #1
Home Theatre effect
When a DVD is put in the DVD player, the sound goes through the speakers throughout the RV giving a very good sound like a home theatre. But what about when you aren't playing a DVD? When just using the TV, the sound comes out of the TV speakers only. Has anyone been able to set it up so the TV audio also goes through the other speakers in the RV.
georgetown50 is offline   Reply With Quote
Old 07-11-2014, 04:34 PM   #2
Don't know which one you have, but on ours if you change the input of the radio to aux, the sound of the TV goes through the stereo. Try cycling through the inputs of your radio, it's probably hooked up to one of them.
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
alparmer is offline   Reply With Quote
Old 07-11-2014, 04:36 PM   #3
43D18's Avatar
X2 what Al said above
Mike & Suz
2014 Georgetown 351
Pontiac Vibe toad
Buck & Patsy, the boston-mix guard dogs
43D18 is offline   Reply With Quote
Old 07-11-2014, 10:48 PM   #4
GABoy's Avatar
X3 on Al
Chevy Colorado Crew
GABoy is offline   Reply With Quote
Old 07-11-2014, 11:03 PM   #5
To expand on the other repliers, check your tv to see if there is an audio out. Mine has a Tip Ring Sleeve plug (like a stereo headphone). If so connect that to the radio's audio input. Check your TV menu's. If it has one, there will probably be a TV output adjustment on one of the menus that allows you to mute the TV speakers or choose external speakers.
Sans1
2014 3010DS (Ford Chassis) no more
Back to a fiver - after 6000 miles in it, me no likey motorhome
Sans1 is offline   Reply With Quote
Old 07-12-2014, 10:19 AM   #6
chrisbailey13's Avatar
The functionality mentioned above applies to the TV in the Living room, not the front tv (above the windshield) if you have one.
chrisbailey13 is offline   Reply With Quote
Old 07-25-2014, 03:27 PM   #7
I tried doing this and it doesn't work. I'm not sure if DirectTV may have done something to prevent this functionality when they did the installation.
Old 07-25-2014, 03:46 PM   #8
Where is the radio audio input?
Old 07-25-2014, 04:13 PM   #9
VinceU's Avatar
Check the manual in your library or online first. They will show input/output connections on the back. They can be RCA phono plugs or HDMI or both. One you know where they are, remove the radio and check for connections, you'll already know what each is for.
Old 07-25-2014, 04:34 PM   #10
harpman's Avatar
My TV plays trough all the speakers..I just kept trying everything till I finally got it..and honestly I'll probably have to mess with it again next time we go out
831RESS FLAGSTAFF
F150 FORD ECOBOOST
harpman is offline   Reply With Quote
