Old 01-31-2015, 05:57 PM   #1
Hjs12e's Avatar
Hot water cleaning
2013 Georgetown 360 xl
I noticed when draining the hot water heater that there is a lot of sediment on the bottom. Does anyone have any ideas on removing the sediment?
Harley (Cigar six)
Hjs12e is offline   Reply With Quote
Old 01-31-2015, 06:13 PM   #2
I use one of these and it works great!
Item
Bizmark is offline   Reply With Quote
Old 01-31-2015, 06:52 PM   #3
Iggy's Avatar
Harley (Cigar six)
Harley you can just stick a hose in the with a small nozzle and fill her up and remove hose and it will come out all over the street.
You can also find a flexible tube that is smaller than the tank hole and attach to a hose. I'm sure you got the idea now and can modify something up.
Good luck
Old 01-31-2015, 07:27 PM   #4
Flybob's Avatar
If there is a lot of crud in the bottom of the HW tank, you can screw a short piece of PVC pipe into the drain/anode hole, then use the referenced flushing tool to spray it. The pvc pipe keeps the crud from running down the side of the RV.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 01-31-2015, 07:29 PM   #5
buddyu's Avatar
Harley (Cigar six)
From what I have read that is why the line to the toilet always gets clogged with the sediment. It seems for me this only happens when I am not hooked up to city water. When we finally get a warm weekend I am going to drain and flush my hot water tank.
buddyu is offline   Reply With Quote
Old 01-31-2015, 07:36 PM   #6
Iggy's Avatar
Have you checked the water tanks anode rod?
I bet its gone.
Suburban Water Heater Anode Rod Magnesium 2 PK 232767 | eBay
Old 01-31-2015, 08:17 PM   #7
buddyu's Avatar
I bet its gone.
Iggy
I haven't yet. Which one do we need for our 378's? I think I will order one before I drain and flush it. It's not easy getting down on the floor to clean the line when you have had a knee replacement so hopefully a new anode rod will do the trick!
Buddy
Old 01-31-2015, 08:23 PM   #8
buddyu's Avatar
Oops. I assume the one you posted from EBay is the one I need?
Old 01-31-2015, 08:48 PM   #9
Iggy's Avatar
Yes they are.
Camco also have ones the same size for a 10 gal Suburban water heater tank.
The one on Ebay are really reasonable for two for $29.99 with free shipping and no tax.
I actually bought 4 of them because if you keep water in the tank they will dissolve as they are suppose to.
Mine last about 1 year but I use my rig a lot.
They range from 9" to 9.5" in length
3/4" nipple threat
But you need a 1 1/16" socket to get them out.
I also added a copy of the 10 gal DSI Subrban water heater
Read page 5 about anode.
Old 01-31-2015, 08:50 PM   #10
Hjs12e's Avatar
Thanks all for the suggestions, will purchase the wand asap!
hot water, water
