Originally Posted by alsimmon11
I have a 2010 378. I used the hot water heater yesterday, worked fine. Today I turned it on and can hear the igniter and see it working, but it is not firing off. I have plenty of propane. Any suggestions.
If the igniter is snapping and you can smell propane at the water heater, you have a bad mixture. Check the flue and burner area for spider or wasp nests.
If you do NOT smell propane, check the gas solenoid.
