Old 09-18-2014, 09:27 PM   #1
Red face Hot water leaking 377xl black water flush
when i use the black water flush you here it working but also it starts leaking out from the hot water compartment have no drawings on the pluming can anyone please help me with any pluming drawings 2013 377 xl
thank you much steve.
steve1948 is offline   Reply With Quote
Old 09-18-2014, 10:38 PM   #2
steve1948: Here's a thread that I started with the exact same issue you had. You'll likely need to get the nozzle on the black tank replaced.
Black Tank Flush Leak
2013 Georgetown 350 XL
2009 Pontiac Vibe toad
chill960 is offline   Reply With Quote
Old 09-18-2014, 11:24 PM   #3
do you need to remove the hot water heater
thank you for the information any more info would help
Old 09-19-2014, 07:10 AM   #4
chrisbailey13's Avatar
Steve,
The HW Heater shroud needs to come off so you can see/access the nozzle that is leaking.
2014 Georgetown XL 352QS
2013-2017 Days Camped-215
chrisbailey13 is offline   Reply With Quote
Old 09-19-2014, 07:43 AM   #5
The techs that worked on mine removed the hot water tank for a bit more access, but as chrisbailey13 said, just the shroud needs to come off then the whole panel flips up for access.
black, black water, hot water, leak, water, water leak
