Old 06-02-2015, 01:13 PM   #1
buddyu's Avatar
Hot Water Reset Light
Does anyone have any thouhts as to why the hot water reset light on the Command Center control panel keeps coming on "at times"? i don't think it should make any difference but the propane is down to quarter full.
Seems like on this trip if something can go wrong it will. Started with a clogged toilet....
buddyu is offline   Reply With Quote
Old 06-02-2015, 01:22 PM   #2
bubbles's Avatar
It may come occasionally when lighting (doing a re-light) but if it goes out then there should be no problem. Sometimes a strong wind blowing into the igniter on mine will do as you say yours does. I just disregard the light unless it's on steady for awhile. If it's a continuous thing every time a re-light is happening then an adjustment may be required.
Old 06-02-2015, 01:25 PM   #3
wmtire's Avatar
X2. The light will usually come on as the Direct Spark Ignitor is making sparks to ignite the propane. Once ignited, the light goes off.
You will notice this the first time your propane lights when your turn the switch on...and then on occassion when the water cools off enough in the tank that the thermostat calls for heat again...then the DSI makes sparks to ignite the propane for the burner to heat the water back up to temp.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
hot water, light, water
