Forest River Forums
Sunline User Photos
Old 10-21-2011, 01:55 PM   #1
hot water tank bypass
Hi everybody
I just purchased a 2007 Georgetown 378 this summer. what I'm wondering
about is. Is there only one bypass valve for the hot water tank? It's time
to winterize unfortunatly.
alpinemike is offline   Reply With Quote
Old 10-21-2011, 02:22 PM   #2
Moderator
Unfortunately, this gets asked and answered often. If you will do a search on here, you will find numerous threads with varying explanations. This is the first one I found with Gergetown, GeorgeTown water heater by-pass
There are many others, some with diagrams. Search and ye shall find.
Sorry, can't help more, but sometimes you got to do your homework like the rest of us did.
Windrider,
Too many toys, not enough time.
2001 F150 SuperCrew
2002 Jeep Wrangler
1978 Cessna 152
2000 Honda 750 Nighthawk
2008 Work and Play 18LT
windrider is offline   Reply With Quote
Old 10-21-2011, 02:23 PM   #3
too fast turbo sled
f1100turbo's Avatar
One location for valves yes.
You will most likely have three valves to turn tho
2005 silverado 2500hd pro ride 5th
2011 palomino sabre 32 bhok-6
2012 arctic cat f1100 turbo limited edition sno-pro
Ron and Amy Benhart
2012 nights camped (5)
f1100turbo is offline   Reply With Quote
Old 10-23-2011, 10:57 PM   #4
We have an '07 Georgetown 359TS. In the basement cabinet where the propane tank is located, there is an access to the hot water tank ( a round opening). I reach around inside until I find the valve and I close it. This prevents water from entering the hot water tank, so now drain the hot water tank and you should be set to go. You can also put RV antifreeze in the line while it is draining. Because I use the MH in the winter, I do this about 12 times per winter and have never had a frozen line.
The Hankster
'07 Georgetown XL, 359TS
Hankster is offline   Reply With Quote
Old 10-24-2011, 10:18 AM   #5
Anacortesians
Our 02 325 only has one hand valve. I guess there's a check valve somewhere to prevent back flow into the heater. In this particular layout, the water heater is in a cupboard at floor level aft of the kitchen.
I'll be doing our winterisation this week. Forecasts are for lows around 36F, so it could drop below freezing, given the accuracy of the forecasts out here on the West coast. We've already had one overnight where there was rime ice (what we Brits call "hoar frost") on the north facing roofs in the morning. Outside min/max said the minimum was 38F that night.
Frank and Eileen
1 Rescued Male Labrador - Bailey, 9 in July
02 Georgetown 325, F53 V10
Old 10-24-2011, 12:01 PM   #6
cfsoistman's Avatar
Originally Posted by alpinemike View Post
Hi everybody
I have a 2007 as well and yes in my case there is only one valve. It is a two way valve that allows water to either flow through or by-pass the water heater. The hot side has a check valve to only allow water to leave the water heater. I'm glad there's only one because the access to it from a 4" Access Cap is just barely reachable.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 10-24-2011, 02:50 PM   #7
Our 378 (2011) has two valves located above the plug in the bottom of the hot water heater compartment that seem to be the bypass valves.
Then there are the two additional valves to bypass the water tank and draw from the bottle of pink stuff. These are in the compartment above the low point drain, behind a plastic plug.
Haven't used them yet, but I think the 4 will do it!
Now wish there was a simple way to do the icemaker...
ohiobill is offline   Reply With Quote
Old 10-25-2011, 03:54 PM   #8
ronhanson's Avatar
My 2009 has 3 valves. Winterizing last week I was suprised to reach up and only feel 2. One of the handles had came off, probably from vibration, and was floating around in the compartment!
Ron Hanson
2009 Georgetown 350TS (bunks)
400W solar, 440AH 6V GC2
2009 Ford Edge AWD Ltd towed
2011 Honda Fit Sport towed
ronhanson is offline   Reply With Quote
Old 10-25-2011, 05:43 PM   #9
Correction! I was wrong, there are three valves above the plastic plug under the hotwater tank! Found out after pumping a gallon of pink stuff
into the hotwater tank this afternoon. Sorry for the incorrect
prior post.
Has anyone else wondered why Forest River put a plug on the winterization hose that won't fit into a standard antifreeze container?
I will say this 378 is more difficult to winterize than any of my previous 3 fivers!
Old 10-26-2011, 03:15 PM   #10
Send a message via Skype™ to Falcon35
ohiobill: I took my hacksaw and cut of the ears on winterization hose plug now it drops in to the antifreeze jug.
The 374 is harder to winterize then our fifth-wheels as well. That is what we get for the extra features like water dispenser and ice maker.
2012 Georgetown 378 2008 Honda Fit
ReadyBrake™ Surge Brake System integrated with ReadyBrute™ Elite RV Tow Bar
Falcon35 is offline   Reply With Quote
» Online Users: 266
12 members and 254 guests
1l243, bama gail, bignugget, bikendan, Greene, HondoPatrick, Namchief, onthelake, Rebel702, shooted, sprayking, srj
Most users ever online was 996, 05-22-2012 at 11:04 AM.
Close [X]
