Old 05-24-2014, 12:29 PM   #1
Seventh Heaven's Avatar
Hot water tank issue
I have turned on our hot water tank by flipping the on/off switch on the inside control panel for the first time In our 2015 351ds Georgetown...I made sure the tank was full and the valves were open and all I get is a red reset button light with no hot water...any suggestions?
Seventh Heaven!!
2015 Georgetown 351 DS
Seventh Heaven is offline   Reply With Quote
Old 05-24-2014, 12:30 PM   #2
Also I checked the breaker and it seems fine!
Seventh Heaven!!
Old 05-24-2014, 12:32 PM   #3
Dijoeboss's Avatar
My red light comes on when I first turn it on, but after the burner lights and heats the water, the light goes off.... I haven't ever had a concern with it NOT working...
Dijoeboss is offline   Reply With Quote
Old 05-24-2014, 12:34 PM   #4
Ok...maybe I am ignorant so forgive me, but do I have to light an igniter...I thought it was automatic...also I was trying to run it electrically not by propane method?!
Seventh Heaven!!
Old 05-24-2014, 12:41 PM   #5
Ford Idaho's Avatar
Off of shore power there is nothing to ignite.
What brand name heater do you have?
Old 05-24-2014, 12:43 PM   #6
Name:	ImageUploadedByForest River Forums1400953385.918498.jpg
This is my unit.
Seventh Heaven!!
Old 05-24-2014, 12:47 PM   #7
Ford Idaho's Avatar
Originally Posted by Seventh Heaven View Post
Attachment 53160
This is my unit.
Nice!
Does it have a on/off switch?
Old 05-24-2014, 12:47 PM   #8
Ok...I flipped the on/off button on that outside unit...how do I know if it ignited? Sorry if I seem ridiculous..first timer!!! I hope to the hang of this soon!
Seventh Heaven!!
Old 05-24-2014, 12:58 PM   #9
Ford Idaho's Avatar
You do nothing for now, it will take a bit before you have hot water.
If you wish you can use both gas and shore power to heat the water faster but why burn thru the propane.
Old 05-24-2014, 01:09 PM   #10
First, Welcome. Hey we were all new at some point.
Your water heater runs off two sources. #1 is propane and #2 is electric 110volt.
With your propane tanks turned on at the valves lite a stove burner to purge any air from the lines. Make sure your hot water tank is full of water by running a hot water faucet until air is purged or you could use valve on the hot water heater. Flip the switch on your control panel and that should light the hot water heater on propane.
If you are hooked up to "shore power" (camp ground power) you could choose to flip the switch on the hot water heater and heat with electric.
If you want to heat water faster turn both inside switch (propane) and outside switch (electric) on.
With the propane switch on you should be able to hear the burner and feel heat at the vent on the water heater.
John And Mary
2016 Venom 3311TQ
2013 CHEVROLET 2500 6.6 DURAMAX
Nights Camped 2012 (7) 2013 (33) 2014 (27) 2015 (34) 2016 (27) 2017 (32) 2018 (34) 2019 (35) 2020 (20) 2021 (5)
Kaboom is offline   Reply With Quote
Old 05-24-2014, 01:21 PM   #11
Like Ford Idaho said why burn both. If your at a camp ground and paying for the electric why burn the propane other than to get faster heating like when taking showers.
Oh, and dont forget to turn off the electric switch on the hot water heater. I try to remember to turn it off before unhooking from campground power. If not you risk the chance of burning out the element.
John And Mary
2016 Venom 3311TQ
Old 05-24-2014, 01:27 PM   #12
I have hot water!!!! Thank you all!!!
Seventh Heaven!!
Old 05-24-2014, 01:30 PM   #13
Ford Idaho's Avatar
Old 05-24-2014, 07:00 PM   #14
This was a little confusing for you, probably. There are two methods of heating the water. 1st is 115 volt electric. That is controlled by the on/off switch located on the lower left side of the water heater outside. 2nd is the propane. That is controlled by the on/off switch located inside. Turn that switch on and you get a red light. Wait several moments and the red light should go out. That indicated that the heater has lit off on gas. If you are on a power pole then use your 115volt electric and save your propane. Or if you have 4 or 5 folks taking a shower one right after another than have both on. It will reheat the water a lot faster.
Lostdog
2011 Georgetown 378TS in FireMist
2013 Jeep Wrangler Toad
Kirby the Old Dog, passed but still in our hearts
Max E. Dog, the new pup
Eureka the Old Cat, still hangin' on
Lostdog is offline   Reply With Quote
Old 05-25-2014, 06:22 PM   #15
I've never had issues with the water heater, but it seems I may have a burnt bulb. I say this because since day one I flip the inside switch to on and shortly after it fires up on LP. The switch itself is black unlike the others that light up for the water pump and arctic pack. There is a red cover right next to the water heater switch that is marked WATER HEATER RESET. It has never come on even after having to reset one of the CBs on the water heater itself.
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
alparmer is offline   Reply With Quote
Old 05-25-2014, 06:51 PM   #16
cjd10's Avatar
I might be wrong but I thought the water heater light only stayed on if the water heater didn't light off the propane
Charleston SC
1 Boston Terrier, 1 Frenchie, Two Siamese
Gonna miss you Toby, Sage, and Izzie. RIP
cjd10 is offline   Reply With Quote
Old 05-25-2014, 07:04 PM   #17
That's what I thought, but from what has been posted it comes on until it lights up. Ours has never come on ever. We are out camping as we speak, and when we got to the park on Friday I flipped the propane switch and thought everything was fine, but an hour later no hot water. Went out and had to reset the right side CB on the tank. No lights inside.
Old 05-25-2014, 07:13 PM   #18
bubbles's Avatar
That red light should have been on. It is an indication that the switch is on and the water heater has not fired off. When first turning the switch on the red light comes on and then will go off. It will stay off if the heater functions normally (heater ignites). It will come back on as an indication that the heater did not ignite and reset the switch to start the sequence again. You indeed may have a burned out annunciator or bad interconnect.
Old 05-25-2014, 07:19 PM   #19
Thanks, that what I thought. I'll have to check the bulb and connections. Will post what I find.
Old 05-25-2014, 08:00 PM   #20
cjd10's Avatar
Mine does come on momentarily until the water heater is lit.
Off topic but how hard is the bulb to change? The one on the water pump switch has quit on mine.
Charleston SC
hot water, tank, water, water tank
