Old 12-01-2012, 09:07 PM   #1
hot waterheater
Can anyone tell me if the hot waterheater is both electric and gas?
pres09 is offline   Reply With Quote
Old 12-01-2012, 09:09 PM   #2
Sorry, the coach is a 2013 georgrtown xl
Old 12-01-2012, 09:16 PM   #3
Herk7769's Avatar
There are several models of hot water heater.
A photo will help us identify yours.
Name:	Hot Water Heater.jpg
ID:	21971   Click image for larger version
Name:	waterheater reset buttons.jpg
HAM CALLSIGN - KC3FFW
Old 12-01-2012, 09:48 PM   #4
I haven't taken possession yet. Delivery date is still a couple of weeks away. Guess i will wait until the PDI to find out for sure.
Old 12-01-2012, 09:50 PM   #5
alsimmon11's Avatar
The model is SW10DE, and yes it has the electric option. With that being said, can the electric switch be left on for long periods of time or should it be turned off after use. Thanks for the help.
alsimmon11 is online now   Reply With Quote
Old 12-01-2012, 09:51 PM   #6
alsimmon11's Avatar
It's the first photo you showed. SW10DE.
Old 12-02-2012, 05:37 AM   #7
To my knowledge, all the electric hot water hearers in at least the newer GT models can left on as long as there is water in them. That being said, if the tank is empty (you have drained it) you must turn off the tank or you will ruin it. Additionally, when stored even with water in the tank, it should be turned off to conserve battery life.
norwood12800 is offline   Reply With Quote
Old 12-02-2012, 08:18 AM   #8
Herk7769's Avatar
The electric heater portion of the Suburban hot water heater is totally independent of the DC/propane portion. The only commonality is the water in the tank.
The electric element being left on (outside black switch) and has no effect on battery life because that circuit does not use battery power at all. (see attached wiring diagrams.
If the propane is turned off and the gas switch is left on, the water heater will attempt to light 3 times, then shut down. The board will remain powered and in this case, if the battery is left connected, it will deplete the battery slightly faster that normal since the other parasite loads (propane detector, clock, etc) will be depleting it anyway.
If you have no water in the tank, NEVER have either system turned on since damage to the water heater will occur; just to different systems.
Name:	AC diagram.jpg
ID:	21974   Click image for larger version
Old 12-02-2012, 10:34 AM   #9
kenandterry's Avatar
Listen to Lou (herk7769)
The man knows of what he speaks!!!!!!!!!!!!!!!
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 12-02-2012, 11:27 AM   #10
alsimmon11's Avatar
Electrical portion is working as advertised. Appreciate the fast response and all the help from all, thank you.
