Old 08-27-2016, 11:11 PM   #1
buddyu's Avatar
House batteries dead
I left the disconnect switch on and now my house batteries are dead. I cannot find a topic on how to charge them. Will running the generator for a few hours do the trick?
buddyu is offline   Reply With Quote
Old 08-27-2016, 11:16 PM   #2
It should but might take more than a few hours, might not.
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
Nights camping in 2016: 19 nights
Miles traveled in 2016: 2,575
uhduh camping is offline   Reply With Quote
Old 08-28-2016, 10:59 AM   #3
CheckSix's Avatar
Can you plug it in? The PD Intellipower should charge them back up but it should take a while.
2012 Georgetown 327DS--->2015 Georgetown XL 369DS
CheckSix is offline   Reply With Quote
Old 08-28-2016, 11:19 AM   #4
buddyu's Avatar
The storage unit has a 30 AMP plug so I will try that. Any guess on how long it will take?
Old 08-28-2016, 11:51 AM   #5
swamprat26's Avatar
Depends how low the voltage got. If too low they may never recover
swamprat26 is offline   Reply With Quote
Old 08-28-2016, 12:00 PM   #6
Flybob's Avatar
Check the fuse after plugging in. If the batteries are very dead the charge current may be high enough to blow a fuse.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 08-28-2016, 06:31 PM   #7
Weekender
Ford1's Avatar
One other note. If the coach batteries are too low, the Disconnect Relay will not be able to pick up. That will prevent the converter from charging the batteries. The best thing to do is put an automotive battery charger on the batteries to get their voltage back to normal, then the relay will activate allowing the converter to maintain the charge.
Ford1 is offline   Reply With Quote
Old 08-29-2016, 07:49 AM   #8
CheckSix's Avatar
Yep, doesn't cost anything to try it. Throw a DVM on the house batteries and see what the charge is. Plug it in and see if comes to life. If so, keep charging. If not, throw a good car battery charger on it (I have a smart charger that is 2/5/10/30amp and I set it to deep cycle and let it manage the charge. The batteries should come back fine, as long as they're not long in the tooth.
Old 08-29-2016, 08:04 AM   #9
Herk7769's Avatar
They are deep cycle batteries. Plug in somewhere. Even with the camper plugged in, it can take a day or so to refill those batteries.
This chart will show you why it takes so long. The initial charge (a few hours) will only recover the batteries ability to produce voltage. It takes a few days to repack the plates to replace capacity (how long they last).
Name:	battery voltage and capacity Curve.jpg
HAM CALLSIGN - KC3FFW
Old 08-30-2016, 10:05 PM   #10
buddyu's Avatar
Ran the generator today for about 6 - 7 hours and got a charge on them.
