Old 08-02-2015, 08:35 PM   #1
house batteries going dead after a couple of weeks
I have a Georgetown 36T and after a couple of weeks of sitting around, the house batteries are dead. When I open the door the stairs will not work. I have to charge the batteries by starting the engine and let it run.
When I am locking up I close the screen and the stairs retract. Then I reach in and shut the main switch off, then close the outside door. Is this happening to anyone else. The engine battery never goes dead.
campingPhil is offline   Reply With Quote
Old 08-03-2015, 07:11 AM   #2
BillMFl's Avatar
There are numerous small drains on a battery even with the switch set to off. For long term storage disconnect the negative terminal. If you are parked near a power source just plug into a typical 110v outet using an adapter on your power cord.
BillMFl is offline   Reply With Quote
Old 08-03-2015, 07:46 AM   #3
If you do that because, otherwise, with the power already switched off your steps stay extended after you exit and close up the coach, that means your steps are still powered when the battery disconnect is off. When you are fooling the step control by turning the battery disconnect off with the door closed, the steps are just sitting there powered and at the ready to extend to enable this "last man out" feature when you open the door to exit. What I ended up doing is having my service provider put a dedicated switch between the steps and the battery to shut the power off completely to the steps, so I no longer have a drain on the battery due to this "last man out" feature. I only use this switch when I put the MH into storage, otherwise it is always on for safety reasons when the MH is active. I haven't had any battery issues since.
BigMac8253 is offline   Reply With Quote
Old 08-03-2015, 08:00 AM   #4
The house batteries will slowly drain due to small but steady demands from things like radio memory, CO or propane detectors, TV antenna amplifiers, etc. Adding a battery disconnect switch or removing the battery cable is one way to prevent this drain, or you can trickle charge the battery with a small solar panel, or you can plug in your shore power cord and let your converter keep your batteries charged.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is offline   Reply With Quote
Old 08-03-2015, 12:45 PM   #5
I had this happen to me, my disconnect switch was not working, had to replace the solenoid inside the control box, cheap part but high labor. Cost was 480.00. But now all works fine. My coach batteries will stay charged for Months. The stairs stay down on the georgetown. Make sure all your lights i n your compartments are off. Good luck
daddio is offline   Reply With Quote
Old 08-03-2015, 05:17 PM   #6
Tim & Lisa Trempert
I had the exact same issue. The batteries had an internal short. New batteries solved the problem and they hold a charge for 4+ weeks without a problem provided that I use the battery disconnect switch. I'd go get your batteries tested. They will read full voltage and seem fully charged, which I guess they are, but they will discharge in just a couple days on their own with nothing at all connected to them.
Tim & Lisa
2011 Georgetown 350
Trempert is offline   Reply With Quote
Old 08-03-2015, 08:30 PM   #7
bend302's Avatar
If you have access to 120 volt shore power I would use a battery tender. Mine will keep batteries fully charged for months. You do need to have batteries tested though.
Bill
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
bend302 is offline   Reply With Quote
Old 08-03-2015, 08:46 PM   #8
Retired Ford Tech
Question Battery Drain
Did you look at the obvious things, like is there water in the batteries or maybe one or both have a bad cell. a battery hydrometer is a cheap investment and it gives a definitive condition of each battery. Also, how old are the batteries?
rvpezzano is offline   Reply With Quote
Old 08-03-2015, 09:27 PM   #9
If you have a LP sniffer/sensor, it may have a switch to turn it off. On my 2008 Georgetown, it is located on the floor near the heater and mine does have a separate switch. If I forget to shut it off, it does have a small draw on the batteries and can drain the over time (although I think it would take longer than a couple of weeks on my 1.5 year old batteries).
Milehghcty is offline   Reply With Quote
Old 08-05-2015, 03:28 AM   #10
Get a solar battery tender from Northern Tool. If you have only one house battery a single solar 2.5 watt tender for $19.99. If you have two batteries then get a 7 watt charger for $44.99 from the same place. They will keep your batteries charged and prevent overcharging.
Reb Kitt is offline   Reply With Quote
battery
