Old 08-16-2016, 06:16 AM   #1
How bout a list
How about a knowledgeable person on here make up a to do list .
After you pull in and park
Set brake kill engine, hang key on antenna knob so you don,t forget to lower it
Hook up shore power or start genset
Extend levelers
Slides out
Enjoy
Ready to leave
Slides in levelers up
Unhook shore
Get out check, do walk around check levelers for up
If anyone wants to change this,please do or add to it
As we are still learning after 2 years
rwehba is offline   Reply With Quote
Old 08-16-2016, 08:13 AM   #2
NCCoachMan's Avatar
We're usually just long weekenders, and more than once a month is a treat. Therefore, I usually drop the water from the low point drains so there's no stagnant water in the lines between trips. Probably not needed, but it's just my thang...
Always physically check and lock cargo doors - we had one open on us on a recent trip.
Check lights. Yeah, that's a hangover from my trailer days, but again, it's my peace of mind.
NCCoachMan is offline   Reply With Quote
Old 08-16-2016, 09:12 PM   #3
wbdavey's Avatar
Here's my checklist. I keep it in the truck and check it right before leaving the campsite.
RV Pre-travel Checklist
o Holding tanks Empty, Valves Closed, Drains Capped
o Water, Sewer, Electric, Cable - Unhooked and stowed Bumper caps installed
o Roof Vents, Windows, cupboards closed; TV Antenna down
o Coffee Pot other loose items secure and stowed
o Refrigerator on Auto or Off
o BR TV removed from wall, stowed in closet
o H2O pump, Furnace, Water Heater – OFF (SWITCH INSIDE HEATER DOOR)
o Slides lubricated, Tops clean, retracted
o Jack and Stabilizers fully retracted
o All Exterior doors and compartments locked, stairs folded
o Lights, Safety Chains, Break Away connected – Hitch LOCKED
o Towing mirrors tight and adjusted
2015 Rockwood Ultra Lite 2604 WS. Rear LR, large street side slide with small wardrobe slide in BR.
2014 Ram 1500 Eco Diesel Laramie Quad Cab.
wbdavey is offline   Reply With Quote
Old 08-16-2016, 09:17 PM   #4
CaptnJohn's Avatar
While stopped in a left turn lane today saw a TT flying by,,,, steps still down.
2022 Montana 3855 BR
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
CaptnJohn is offline   Reply With Quote
Old 08-17-2016, 03:22 PM   #5
Coming from a Northern Climate I never ever put the emergency brake
on. It seizes up and sticks.
Ian Walker is offline   Reply With Quote
Old 08-17-2016, 03:30 PM   #6
chrisbailey13's Avatar
Extend levelers
Slides out
Enjoy
Ready to leave
Unhook shore
I leave the engine running while deploying/retracting the stabilizers...
2014 Georgetown XL 352QS
2013-2019 Days Camped-502
chrisbailey13 is offline   Reply With Quote
Old 08-17-2016, 04:14 PM   #7
Block it before you drop it.
mike.t is offline   Reply With Quote
Old 08-17-2016, 04:20 PM   #8
kentdavido's Avatar
the list
I always follow the same set up and dismantle. Except, we had the rig park at the house overnight. We were detailing the inside so we had the rig leveled and the slides out. That evening I pull in the slides and kept the rig level. Next morning I went out to move the rig back into storage when I fired up the engine and put him into reverse. Well, all hell broke loose. Lights flashing, a huge drop and I freaked out. Thank God the parking brake was on and everything worked the way it was suppose to otherwise we could have been replacing some jacks. So, always check to make sure the jacks are up.
kentdavido is offline   Reply With Quote
Old 08-17-2016, 04:38 PM   #9
MADELEINE LEO STERKOWICZ's Avatar
Checklists
Have made many checklists and am attaching them for your convenience. I found them very helpful ... especially for not forgetting to lower the TV antenna.
MADELEINE LEO STERKOWICZ is offline   Reply With Quote
Old 08-17-2016, 04:56 PM   #10
KAS
True! I wish I could do the same. My emergency brake drags when I first start driving, because I have to use it to park in my severely sloping driveway. Also, my favorite campsite isn't level and I have to drive up on levelers, so I use it too.
KAS is offline   Reply With Quote
Old 08-17-2016, 05:10 PM   #11
CaptnJohn's Avatar
I'm going to make a note ~~~
Make lists.
Old 08-18-2016, 07:19 AM   #12
Wolverine 1945's Avatar
Extend levelers
Slides out
Enjoy
Ready to leave
Unhook shore
I do like the hanging of the keys on the TV antenna cranked !!!
Even thow the DW can't reach the knob !!!
Wolverine 1945 is offline   Reply With Quote
Old 08-18-2016, 06:24 PM   #13
Don't forget the last on the list.
DW in Car��
Just Kidding.
JW DUKE is offline   Reply With Quote
Old 08-18-2016, 06:36 PM   #14
KAS
DW in Car��
Just Kidding.
That would only happen once!!!!
Old 08-18-2016, 06:47 PM   #15
CampingGator's Avatar
Lists are well and good, but we ALWAYS do a walk around before we pull out. We BOTH walk around. Does not hurt and sometimes we find things.
_____________________________________________
2010 Ford F-150 Crew Cab
2015 Salem Hemisphere 263RL
CampingGator is offline   Reply With Quote
Old 08-21-2016, 10:19 AM   #16
Adventure Trek RV Checklist app for smartphone or tablet. It's a comprehensive list that you can customize by adding items or deleting items. Works great for me and is there when you need it.(I tend to lose paper things) Best of all, it's free.
Harold Fay is offline   Reply With Quote
Old 08-21-2016, 10:44 AM   #17
Iwannacamp's Avatar
Don't have to be from north. My brakes have frozen here.
2017 Puma 297RLSS
Old 08-21-2016, 11:01 AM   #18
Iwannacamp's Avatar
Thanks for that. I added a couple to my trailer "go pick-up list". I may or may not have thought of.
2017 Puma 297RLSS
Old 08-22-2016, 04:57 AM   #19
Emergency brakes do that if they do not get used regularly !!!
You should always set your brake when parking on an incline,,, before you shift into Park !!!
