Old 07-23-2015, 06:35 PM   #1
How do I get residential frig out?
The saga of my refrigerator not working on my new Georgetown 364TS continues. I called Forest River and they said that Frigidaire requires their own people to work on their refrigerators. So I called Frigidaire who sent one of their service people out today. First, the guy didn't really act like he had a clue what he was doing. When it looked like he was trying to listen for something and I had the coach AC on he turned around to the thermostat like he was going to turn it off and I said would you like me to turn off the AC and he said yes. Come on, maybe I'm picky but don't start touching stuff in my RV without my permission. So he listened and said the fan is working. Yes but as you can see on the display, the refrigerator temp is 62 and the freezer is 49. I'm pretty sure that for a brand new refrigerator that is not operating as designed. Sheesh.
Then he said I need to come out when there's two of us. What? I just sighed and said okay and then he makes a phone call and is on hold for like 20 minutes. Turns out he's calling Frigidaire tech support. They finally answer and run him through a bunch of diagnostics and then they diagnose a bad evaporator. Then he calls his boss and says this thing is in an RV and I don't know how we're going to get it out of this little hole its in. So finally he turns to me and says I've got two more calls to go on, let me talk to my boss and I'll call you. I said okay.
So he calls me later and said I can order the part but we're not going to move the frig out of that hole, you need to get someone else to do that. Can you take it to the dealer and have them do that? I said are you kidding me? You want me to take it to the dealer, have them move it so its insecure and then drive it back home so it can fall over on the drive home? Really? He said well I don't know what to tell you. I said well Forest River says Frigidaire requires me to have you guys work on it and you guys are saying you won't work on it so where does that leave me? He said maybe you should call Forest River and see how they got it in there. I just said okay, I'll call you back. I have a headache now.
So I went out and took some pictures. It is hard to see inside there but in looking at the pictures, it looks like maybe its sitting on a solid ledge in the hole. My question if anyone is still with me is do you know how the refrigerator is installed into this "hole" ? If you look at the last picture you can kind of see where the leveling leg is sitting on what looks like just a 6" platform. Or maybe its just wishful thinking. I don't see any kind of cap or anything else down there that makes any kind of sense. I can't get down there with a flashlight right now and look at it because I had surgery and can't wear my glasses so even if I looked I wouldn't see a thing. If anyone has any suggestions, I'm all ears. I'm going to call FR tomorrow to see if they can assist. Thanks for any help.
Marcusfan
ID:	83919   Click image for larger version
ID:	83920   Click image for larger version
ID:	83921   Click image for larger version
2016 Forest River Georgetown 364TS
marcusfan is offline   Reply With Quote
Old 07-23-2015, 06:46 PM   #2
tilap's Avatar
Please post the results. Because ever since I got my RV a year ago, I keep asking myself what if? How do I? Still wondering how I would get this thing out if needed.
Denis, Forest river Georgetown XL 377 towing a 2014 Ford Explorer.
tilap is offline   Reply With Quote
Old 07-23-2015, 06:51 PM   #3
I think the Teck is doing the Proper thing,let the Dealer Remove it! then the Teck can work on it! It is NO different than a Totally enclosed unit in a House that Cant be simply (Rolled/Pulled) Out! Youroo!!
Old 07-23-2015, 07:22 PM   #4
Sbryant's Avatar
To take it out on my GT 36, first I removed the bottom grill under the freezer by raising it up. Next remove the two screws behind the grill on each side at the front. My fridge is now ready to come out. I couldn't pull it out, so I tilted the motorhome over using the jacks. I made a ramp, and with the help of gravity, it rolled right on out. I tilted the mh the the other way to get it back in.
Sbryant is offline   Reply With Quote
Old 07-24-2015, 07:33 AM   #5
Thanks for the PM's that I needed to update my signature with the new coach! I think that was confusing everyone.
Marcusfan
Old 07-24-2015, 12:27 PM   #6
Director, FROG
F.R.O.G.'s Avatar
I'd call Kevin Stratton at Georgetown Service & Warranty to see what he suggests on getting it out or how it was installed. Kevin's phone number is (574) 206-7611.
Bob Byrne
Director, Forest River Owners' Group (FROG)
frog@forestriverinc.com
www.forestriverfrog.com
F.R.O.G. is offline   Reply With Quote
Old 07-24-2015, 12:34 PM   #7
5 hole's Avatar
absolutely 100% correct in having the dealer pull the fridge. You do not ask your flooring guy to un-install and re-install a toilet, if they make a mistake it is their fault and they are not covered as they are not authorized or proficient in doing things outside of their scope
Stefan
2014 - Sabre 36 QBOK
Nights camped 2014 - 38
Nights camped 2015 - 46
Nights camped 2016 - 43
Nights camped 2017 - 2
5 hole is offline   Reply With Quote
Old 07-24-2015, 09:08 PM   #8
Yeah I already tried to call Kevin to see what they recommended. I had to leave a message. Last time I called him it took a couple days for him to call me back. I'm sure he will get back to me next week.
We're out camping this weekend the old fashioned way. A cooler full of ice and everything in the freezer section at 49 degrees. Could be a lot worse. At 97 degrees at least the AC works!
Old 07-25-2015, 01:41 PM   #9
abjb's Avatar
YEP
Start over
Take it to your dealer tell them to call you when it's ready.
They'll call Frigidaire.
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
Old 07-25-2015, 03:14 PM   #10
Vince and Charlette's Avatar
Travis is the other Georgetown tech rep. He's done amazing things to help me through some problems. His direct number is 574-206-7635. Since I live in Ohio, I assume the tech reps have regions. (By the way: Wednesday, I called Travis about a bad inverter remote switch. I go it UPS the next day! You just can't beat that kind of service.
2018 Berkshire 38A
Vince and Charlette is online now   Reply With Quote
