Old 08-21-2014, 03:48 PM   #1
How do leveling jacks work??
Well they called to tell me the unit is fixed and ready to pickup ...so I need a crash course in how the leveling system works so I know for sure they fixed it .. (The inspector will not be there tomorrow) They tell me they replaced the manifold and some other parts... And is now functional ..
Any help would be appreciated.. Thank you
2010 Georgetown 300FWSSouth Florida
speedjester is offline   Reply With Quote
Old 08-21-2014, 04:33 PM   #2
RudysWorld's Avatar
On my 2011 there is automatic and manual leveling. With automatic you just press a button and the leveling system automatically levels the MH. I use the manual a lot. That way you turn the unit on and indicator lights will what areas are low. My leveling system says to start from the front lower the jacks and then lower the rear till those lights go off. Then if the right or left lights are lit press those until that light goes off. Then the center light flashes and the MH is level. For both manual and automatic the parking brake is required before starting. You may want a level to check for level, my manual on the leveling system says to use a 4'. Hope that helps, I sure others will give you ideas also. I downloaded the owners manual for mine online to get the information I have.
Rudy - 10 year old long haired dachshund, RIP
2011 Georgetown 350TS
2013 Chevrolet Equinox toad
RudysWorld is offline   Reply With Quote
Old 08-21-2014, 04:43 PM   #3
undr60's Avatar
The motor should also be running and in park.
undr60 is offline   Reply With Quote
Old 08-21-2014, 06:40 PM   #4
Should all jacks bee dry?? Can there be some weeping??
Old 08-21-2014, 06:40 PM   #5
Any test I can do other than just run it??
jacks, leveling
