Old 05-04-2015, 04:39 PM   #11
wmtire's Avatar
Originally Posted by MKClark View Post
I have the same water heater in my Windjammer. Found the same switch. Does it have to be on if you are running on gas to heat the water? I have been just filling the tank and then turning on the water heater switch on the inside control panel.
MK Clark
No, that switch is for the electric heating element only. The inside DSI switch is what you use for the propane part.
This explains the two different switches and modes of water heating:
Suburban's electric switch and much more
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 05-04-2015, 04:46 PM   #12
WDK
WDK's Avatar
I have found that if the electric is on and the water reaches temperature, the propane side will not turn on....the burner will not light though I have not checked to see if the reverse is true.
WDK
WDK is offline   Reply With Quote
Old 05-04-2015, 05:11 PM   #13
Witch Doctor's Avatar
WDK
Yes it is true, If it's the same temp and shut off it will not come on with the electric. they both have the same temp disk or limit if you want to call it that. Even through one disk is for propane side and one is for the electrical side. That is why you can use them both for a faster recovery. Once it hits the temp no matter what degree you have in 120 or 130 they both will shut down. And then come back on to reach temp again.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 05-04-2015, 05:32 PM   #14
WDK
WDK's Avatar
...though the question is will they both come back on....if that's the case. It's something I do not want....faster recovery is fine but I can wait. I usually, depending on the cost of propane where I am at, alternate between electric and gas just to make sure both are working properly....it's a back up or a cost saver.
WDK
electric, heater, hot water, water, water heater
