Old 04-07-2015, 09:02 AM   #11
The Wandering Irishman's Avatar
Originally Posted by scott41672 View Post
Thanks everyone! I got it going! ALL GOOD!
Now I just have to figure out why the Water/Ice in the fridge is not working...Tried to prime it...no water or anything...Tried it with the filter and without the filter.
In our 351DS there is a shutoff valve (pop-up style) in the line that feeds the fridge. Sorry I don't know where this is located in your model, but in our 351 it is in the cabinet below the sink\counter nearest the fridge. I had shut mine off and disconnected the fridge line to drain it during winterization. Perhaps this is the situation with yours as well. Check your cabinets and access panels around the fridge for it, it should be the standard water line with a shut off valve of some type with a step-down to the smaller, standard fridge water line.
Hope that helps.
Tom
2014 Georgetown 351DS, 5 kids, 2 dogs, and an amazing wife!
The Wandering Irishman is offline   Reply With Quote
Old 04-07-2015, 07:34 PM   #12
It was in an outside compartment and had to be reset.
scott41672 is offline   Reply With Quote
Old 04-08-2015, 02:13 PM   #13
I have a 2015 GT 351 - in the cabinet next to the sink behind the garbage can is a water supply line to the fridge - it has a shut off on it. check that line to see if it is open.
as for the inverter - battery light at coach door on, inverter button at coach door on - fridge will be on. my GFI is in the bathroom - but don't think the fridge is on that circuit.
dirievi is offline   Reply With Quote
Old 04-08-2015, 04:05 PM   #14
Yep...that was the issue. The water line was off.
fridge, inverter
