Old 03-09-2015, 11:00 AM   #1
How does fridge turn on with inverter?
Have a 2015 Georgetown 335ds....first timer.
We have a built in inverter that is supposed to power the fridge.
Aside from just turning on the inverter, is there another step? My fridge doesn't turn on.
First time with a residential fridge.
scott41672 is offline   Reply With Quote
Old 03-09-2015, 01:17 PM   #2
Iggy's Avatar
Hi and welcome Scott.
Yes the invertor need to be on but you also need to make sure the coach batteries are charged and the MAIN battery disconnect switch is ON.
The coach batteries if charged will supply 12 volt DC power to the invertor and the invertor changes the power from 12 volt DC to 120 volt AC power which runs your refrigerator.
Hope this helps you understand the circuit.
Good luck
Iggy is online now   Reply With Quote
Old 03-09-2015, 01:57 PM   #3
GABoy's Avatar
There is also a gfci outlet on side of the inverter that supplies the ac line. Make sure it's not tripped.
2014 Georgetown 351DS
Chevy Colorado Crew
GABoy is offline   Reply With Quote
Old 03-10-2015, 08:22 AM   #4
bigben's Avatar
I am with GABoy. Find the GFCI and make sure it is reset. As a rule, this outlet is difficult to find. But find it you must.
US Army - Retired and loving it with our Georgetown 351DS and now our Thor Challenger 37TB.
bigben is offline   Reply With Quote
Old 03-10-2015, 12:14 PM   #5
Question about GFCI
I am a newbie so I know nothing, but are you guys sure the refrigerator is connected to a GFCI? It is not commonplace in regular homes in Texas, so I'm just asking.
rainsmik is offline   Reply With Quote
Old 03-10-2015, 12:54 PM   #6
fridge inverter
I have a 2012 Crusader 5th wheel, I am confused on the inverter, how do you turn it on? My fridge seems to run continuously and my electric bill seems very high due to my fridge always running. Am I doing something wrong when I am on electric power, should the fridge be running off the batteries? I am also new to this and any help on this would be helpful to me.
brireey is offline   Reply With Quote
Old 03-10-2015, 07:06 PM   #7
bigben's Avatar
Absolutely positive on my 351 and a other FR owners that I've shown.
Not sure about the fridge running constantly but in another life I worked for an appliance manufacturer and IMO something is amiss. A couple of things:
1. Either the the reefer is leaking refrig air (a bad seal)
or
2. Bad sensor and the compressor is running.
In either case, you are headed for a problem with a worn out compressor.
Old 03-10-2015, 07:08 PM   #8
bigben's Avatar
Positive on 351s
It is a shame that dealers don't make it a point to show this in walk throughs.
Old 04-06-2015, 11:05 PM   #9
Thanks everyone! I got it going! ALL GOOD!
Now I just have to figure out why the Water/Ice in the fridge is not working...Tried to prime it...no water or anything...Tried it with the filter and without the filter.
Old 04-07-2015, 07:35 AM   #10
Starboard's Avatar
So where was the GFCI outlet??
We should start a forum thread for all the locations this GFCI was found.
Starboard is offline   Reply With Quote
fridge, inverter
