Old 09-24-2012, 07:19 PM   #11
copsuno's Avatar
Just curious, no one has said how you determine "Level". Just asking.
Logic will carry you from point A to point B. Imagination will carry you everywhere. "Albert Einstein". 2011 Georgetown 360, Bride of 45yrs, and 2014 Chev Equinox toad, what more could you ask for.
copsuno is offline   Reply With Quote
Old 09-24-2012, 07:25 PM   #12
WestCoastRV'er's Avatar
Generally you need to ensure that you are level from front to back as the fridge is on the side.
Level from right to left (side) first. From front to back is easy.
2011 2902ss Rockwood Ultralight
2008 Grand Cherokee 3.0L Diesel (255 hp @ 2900 rpm / 430 lb-ft @ 1,400-2,800 rpm)
3P ProPride Hitch
RV Mods
Wandering RV Life
WestCoastRV'er is offline   Reply With Quote
Old 09-24-2012, 07:45 PM   #13
Another rat in the race
jar3316's Avatar
Take a level (a good one not the little cheap ones) and check your fridge floor to your floor in the middle of the trailer (near the door is easiest) counters if its a motor. If they match then use the floor / counter (easier). level side to side then front to back. a good level is less than .5 degrees off from center to line edge of bubble. If it still doesn't cool have it serviced you might have a small leak and be low on ammonia.
A rainy day camping is better than any sunny day at work
2004 F250 V10 SD Xcab 2011 Wildwood T26BHXL
jar3316 is offline   Reply With Quote
