Old 04-17-2012, 06:45 PM   #1
Kanadian Kamper
kenandterry's Avatar
How long do your house batteries last?
We have a 2010 Georgetown 330TS. What camping we've done so far has always been with full hookups. At all times, the status of the house batteries according to the electronic monitor panel have always showed full charge.
On the last night travelling back home, we had to stay overnight at our first "Wal-mart" campout........actually quite fun. The overnight temperature was cold enough (35F) that we had to run the furnace, set to maintain 68 degrees F. Before going to bed, the control panel showed full charge for the batteries.
At around 4AM, we heard a faint alarm beeping, and I found it was originating from the furnace compartment. When I checked the control panel, the LED status for the batteries showed 1 LED out of 5. I immediately started the RV engine, moved us away from the other campers, and started the generator to run the RV on AC power. Battery status improved to 5 LEDs and we slept for a few more hours.
Is it normal that the batteries should develope this failure in that amount of time? I would have thought that house batteries should be able to support "dry camping" with just the furnace for at least one overnight.
Anyone???????
Ken and Terry
kenandterry is offline   Reply With Quote
Old 04-17-2012, 06:47 PM   #2
Rugged Brown's Avatar
The furnace will drain the battery quite quick, if it runs often. I have experienced the same on cold nights.
Terry/Bernadette
Lily the Yorkie
2019 Dodge Ram Sport 1500
2019 FR Vibe 28RL
Rugged Brown is offline   Reply With Quote
Old 04-17-2012, 06:49 PM   #3
TURBS's Avatar
It also would depend on general condition of the battery as well as size.
Old 04-17-2012, 08:13 PM   #4
Triguy's Avatar
Ken,
Out of curiosity, does an MH like the Gtown come with batteries or do you supply them yourself? I've always wondered.
More to your question, what are the total Ah for your House batteries?
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 04-17-2012, 08:43 PM   #5
Originally Posted by Triguy View Post
Ken,
Mine came with two 6 volt batteries. Not sure how many amp hr they are
Old 04-17-2012, 09:19 PM   #6
Yep the furnace will drain the batteries overnight.
Happy Trails
fbconsults
(Forrest and Donna)
2011 Georgetown 378TS
2011 Ford Escape V-6 4X4
fbconsults is offline   Reply With Quote
Old 04-17-2012, 09:33 PM   #7
Kanadian Kamper
To Triguy..........
Yup. Forest River supplies the batteries in their motorhomes. I Don't know the toal amp hours........documentation is not their strongpoint! nI do know that mine have stickers on them saying manufactured June 2008.
To Iggy.......
Are you sure your house batteries are 6 volt batteries? Your photo looks like they are 12 volt. I see what appears to be two rows of cover caps on each battery, and if there are 3 cells for distilled water under each cover cap, then that's 2 volts per cell times 6 cells per battery equals 12 volts.
Ken and Terry
Old 04-17-2012, 09:42 PM   #8
VinceU's Avatar
Originally Posted by kenandterry
To Triguy..........
To Iggy.......
Correct, the pic shows batts in parallel, not series
Old 04-17-2012, 11:07 PM   #9
ronhanson's Avatar
My Georgetown came with 2 group 27 12v batteries. No problem running a furnace overnight with some lights but I did replace them with (4) 6v golf cart batteries pretty quickly.
Ron Hanson
2009 Georgetown 350TS (bunks)
400W solar, 440AH 6V GC2
2009 Ford Edge AWD Ltd towed
2011 Honda Fit Sport towed
ronhanson is offline   Reply With Quote
Old 04-18-2012, 12:19 AM   #10
Originally Posted by kenandterry View Post
To Iggy.......
YEP they are 12 volt batteries and not 6 volt.
I have no idea why I said 6 volt....
Maybe I saw 12 volt batteris and saw 2 so I divided by 2....
Old 04-18-2012, 07:23 AM   #11
Triguy's Avatar
To Triguy..........
Hi Ken,
So assuming that you also have two group 27 12 volt batteries at about 105Ah each, you have a total of 200Ah. Since you dont want to discharge less than 50%, normally this would provide a useable 100Ah. Depending on how how much you were drawing while staying at Walmart, you should have had enough.
But with the batteries being 4 years old, I would check that they are holding their charge. It's hard to predict the life of a battery - lots of variables- but the one group 27 I had on our old camper only lasted about 4 years IIRC.
Scott
2012 Shamrock 233S
Old 04-18-2012, 07:27 AM   #12
Herk7769's Avatar
A lot depends on the condition of the house batteries when you went to bed. For example:
If you arrived at the WalMart at say 3 PM
Ran out the slide on battery
Then cooked and cleaned up the dishes using the water pump
Then watched TV for an hour or so
Then used the lights after dark for a while
Then ran the heater all night
I would be surprised they lasted that long.
As to the "full" on the panel,
"Full" ain't 100% charge remaining
"Full" is only used when the reference is to the holding tanks (like pressing the "FRESH" tank button)
The "CHARGING" Light, the top most LED, (FULL in "tank talk") Will stay on until the battery voltage drops to 12.1 or 12.15 volts when the second to the top "GOOD" light comes on.
As you can see from the chart "GOOD" is 50%-55% battery remaining
"GOOD" will stay on until the battery voltage drops to about 11.6 - 11.65 volts (+ or - 5%) when the "FAIR" light will come on.
As you can see from the chart "FAIR" is 20% battery remaining.
NEVER use those lights to determine capacity remaining.
Since deep discharge batteries should be recharged before they get to 50% to extend useful life, you can see how utterly useless the battery monitor is in ALL RVs.
Also battery capacity (as a total of amps, available DROPS as the amps required increases - see chart) The blower is a high draw item and will suck a low battery quicker than a "more full" one.
Your batteries could have been almost shot when you went to sleep.
Name:	Charge Chart.jpg
ID:	12324   Click image for larger version
Name:	battery voltage and capacity Curve vs Discharge Rate.jpg
File Type: pdf Micro Monitor Panel Troubleshooting.pdf (149.2 KB, 44 views)
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 04-19-2012, 01:47 PM   #13
Kanadian Kamper
Lou.....
Your attention to detail when providing answers is absolutely scary!!!!!!!
We had been travelling all day. We deployed the bedroom slide only, as we were in a Wal-mart. I was extremely careful NOT to run any lights anymore than maybe an hour before we turned in for the night. TV was not used.
I have to take the RV back to the dealer later this year for warranty work and I will have them do a LOAD TEST then to check the batteries. I agree that with the fact the batteries are 4 years old, maybe their time is up anyway.
Thanks for all your help and stats.
Ken and Terry
Old 04-19-2012, 08:45 PM   #14
judy3972's Avatar
Send a message via MSN to judy3972
Question?
What do you mean watch TV?
Do you have a special Tv or does the one in the MH run on battery and not just electric?
Life's a journey, enjoy the trip.
Phoenix, Az.
judy3972 is offline   Reply With Quote
Old 04-19-2012, 08:47 PM   #15
Herk7769's Avatar
Originally Posted by judy3972 View Post
Question?
Sorry, I assumed an inverter. That was one of my very first mods and I sometimes forget not everyone has one.
Old 04-19-2012, 08:53 PM   #16
judy3972's Avatar
I've always said there is no such thing as a stupid question so here goes.
in the MH is an inverter or a converter installed. And short of traveling to the storage lot how would I know. We have a Sunseeker MH
Phoenix, Az.
Old 04-19-2012, 09:05 PM   #17
Herk7769's Avatar
This should be a new thread, but I will answer quickly.
The power center (where the circuit breakers and fuses are) contains a CONVERTER. It "converts" 120VAC (shore power) to 12 volts DC to run your campers DC equipment and charge your batteries.
An INVERTER (not normally part of the camper's package) takes straight line DC (battery) power Boosts it to 120 volts and "inverts" it every 1/60th of a second creating 120 volts alternating current that can run your TV and charge your laptop etc when you are NOT plugged into shore power.
A "pure" sine wave inverter creates a smooth wave form that is very computer and TV friendly. They are also pretty expensive compared to "modified" sine wave (more jaggies in the wave form) inverters (that just might work with your tv and computer; but maybe not.)
Pure Sine Wave vs. Modified Sine Wave Inverters
Unless you have a HUGE battery bank and a honking big inverter you will not be able to run large current draw items off the battery bank like the microwave, an electric heater, or coffee maker.
Hope that helps...
Old 04-19-2012, 09:45 PM   #18
judy3972's Avatar
It maybe making it's way into my brain now.
Phoenix, Az.
Old 04-21-2012, 09:54 PM   #19
jsutherl's Avatar
You also might consider installing a battery monitor. I installed a Xantrex LinkPro about a year ago and so far I'm very happy with it. It'll give you a much better idea of how much power you have left. It'll tell you that both in apm/hours, percentage and time.
I really like it when I'm using the inverter and watching a movie and I've got some lights on. I can glace at it and know that I've got X hours of power left with all the stuff I have on right now.
Here is my thread from when I installed it.
http://www.forestriverforums.com/for...tor-10227.html
There are several other brands of these too. I know Lou uses a different one that's been working for him for a long time.
2008 Georgetown SE 350DS BunkHouse
jsutherl is offline   Reply With Quote
Old 05-02-2012, 05:41 PM   #20
Battery capacity....I just replaced the two 12 volt house battery's in my 2011 Georgetown. Rundown time had gotten to short for dry camping. some thoughts follow
Do a run down test by leaving your M/v in normal settings for gas detectors refrig etc and not connecting the house power to 120. The drop in voltage over the next several days will affect eventuall the door step operation and then the gas detector low battery alarm. Thats the best number of hours you can do with no additional load for lights,water pump, heater fan, inverters etc.
Now look at the amp load you would use in addition to the minimum and reduce the amps/hours appropriately. If you are not satisfied with performance replace batteries.
I have replaced all of the 921 base lights in the cabin with leds of equal output. They are expensive but add to battery life if you need light at night to read etc.
In replacing the batteries go to ones that have a see through casing/white that allows yo to see what the water level is. The access space restricts the ability to monitor water level and any improvement helps
pops
pops is offline   Reply With Quote
battery
