Old 08-24-2016, 03:39 PM   #11
Love quick fill.
2016 Georgetown 364 TSF
2015 FunFinder 242BDS traded for above
2014 Starcraft 1221 Comet traded for above
Modmike is offline   Reply With Quote
Old 12-13-2016, 05:23 PM   #12
Assumes you can get to the cells
Originally Posted by RJJ View Post
I use one of these. OTC 4621 2 liter Battery Filler | eBay
You don't have to see the level, it shuts off and doesn't over fill. Have used it twice now and am happy with it.
2015 Georgetown 329DS
2014 Chevy Equinox
Those work great. However, I have the battery cables (4 house batteries) crossing over the caps and a bundle of heavy gauge wire crossing over the rearmost caps. I can't even get the caps off, much less use the filler!
Grrr, I see a lot of re-routing in my future. Dumb, dumb and inconsiderate way the factory does things. Most things.
Gil a/k/a Captain Justice & Jen
2016 Georgetown XL 378
Toad: 2012 Honda CR-V w/ M&G Engr aux brakes
Amateur Radio KA5GIL vhf/uhf/hf onboard
CaptainJustice is offline   Reply With Quote
Old 12-13-2016, 09:34 PM   #13
I am lucky, I am able to maneuver my cables just enough to fill my batteries. I agree some thought about the end user would have been nice.
2014 Chevy Equinox
RJJ is offline   Reply With Quote
Old 12-14-2016, 07:17 AM   #14
BillMFl's Avatar
I recently changed to AGM (sealed) batteries to avoid this problem. I boiled my previous batteries dry! Some how I managed to forget to check the water levels. No longer trust my memory.
BillMFl is offline   Reply With Quote
Old 12-15-2016, 12:47 PM   #15
We currently own a 2012 378T . I use a wooden handle from an old rake and GENTLY work it under the hydraulic cables to the frame and lift cables up/ off the back caps.The handle is long enough to wedge against entry door when it's open when I work on them. I also use a mirror that has built in light to check liquid level.
PS I was always under impression I had 4 batteries - turns out there's only 2, each one with 2 battery caps
Nomore9-5 is offline   Reply With Quote
