Old 05-25-2014, 09:22 AM   #1
how to check hydraulic fluid level
We have a 2012 Georgetown 360 and are trying to find out how to check the hydraulic level for the slides and landing gear. Can somebody tell us where it's located?
elfi is offline   Reply With Quote
Old 05-25-2014, 09:49 AM   #2
The hydraulic system is located in a storage bin generally will see manifolds, tubing, and a reservoir....there will be level markings on the reservoir for your references.....
ynott96 is offline   Reply With Quote
Old 05-25-2014, 10:02 AM   #3
VinceU's Avatar
Remove the portable entrance step for access. (Use the coke machine key)
Old 05-25-2014, 10:27 AM   #4
Cornelius's Avatar
With the slide-outs in, and the jacks up, the fluid level in the reservoir should be within 1/4" of the top filler cap. The fluid used for the Lippert hydraulics is Dexron/Mercon automatic transmission fluid. It is the older type fluid used typically for pre-2006 automobiles and is readily available at auto parts stores and Wal-Mart. You will probably need a long narrow funnel to get past all the cables and hoses to add fluid.
Cornelius is offline   Reply With Quote
Old 05-25-2014, 10:30 AM   #5
bubbles's Avatar
With everything (slides/levellers) retracted the reservoir fluid level should be approximately 1/2 inch from top of reservoir. A little less fluid would not be a problem.
Old 05-25-2014, 11:02 AM   #6
Iggy's Avatar
This is mine and your may be a bit smaller.
Name:	Motorhome May31_2013 038.jpg
ID:	53261   Click image for larger version
Name:	April 26 2012 038.jpg
ID:	53262   Click image for larger version
Name:	April 26 2012 042.jpg
ID:	53263   Click image for larger version
Name:	April 26 2012 041.jpg
2012 Georgetown XL - 378TS 49,000 miles
(2013 - 98 days) (2014 - 117 days) (2015 - 67 days) (2016 - 115 days)
USAF Retired - MSgt
