Old 08-18-2015, 02:53 PM   #11
Awesome, did you get the 303 fabric for the dash etc... What about the roof? I heard you don't want to wax it as wax gets into the little groves? So what are you using? Keep me posted!
Mr. G
MrGrmpy is offline   Reply With Quote
Old 08-18-2015, 03:41 PM   #12
Mr. G
Old 08-20-2015, 12:54 PM   #13
For the fiberglass roof I use Mop n Glo. Once a year I give it a good cleaning then apply four coats of MnP. Seems to work good. I personally wouldn't want to use anything that would make the roof to slippery in case stop need to be up there to investigate an issue like leaks etc.
sherman12
2011 Georgetown 330TS
Kia Sportage on MasterTow Dolly
sherman12 is offline   Reply With Quote
Old 08-21-2015, 07:50 AM   #14
ME
sparks1032's Avatar
Four coats of MnP?
2008 Georgetown 350TS
sparks1032 is offline   Reply With Quote
Old 08-21-2015, 12:37 PM   #15
Rain X Carnuba wax balls and maguier's yellow wax #26 It's easy on and off and really protects the clear coating. This wax is usually used on very expensive custom paint jobs. Enjoy!
tonytiza is offline   Reply With Quote
Old 08-24-2015, 10:03 AM   #16
Mop n Glo goes on so easy it doesn't take long at all to do four coats as each coat builds it up. May be more than needed but it is so quick what the heck!
sherman12
Old 09-08-2015, 07:38 PM   #17
Ok went out over Labor Day and decided to 303 the decals & wax the rest, WOW... That's a lot of RV...
How do you guys apply the 303?? I found when I sprayed it on a cloth then applied it to the graphic without getting any on the rest of the coach it streaked. If I sprayed the graphic and didn't care if it over sprayed the rest of the coach the graphic looked fine. The I waxed the rest and it shined ☀️...
Do you 303 your entire coach or is wax the better option?
Mr. G
2015 Forest River Georgetown 351DS
Old 09-09-2015, 08:23 AM   #18
Wipe it on with on cloth, before it drys wipe it dry with a clean cloth. I just cleaned the roof of my coach and applyed 303 for UV protection. .
Dogpound is offline   Reply With Quote
georgetown
