Old 07-05-2015, 03:00 PM   #1
How to dismount 335DS TV
Does anyone know how to remove the main 42" TV in a 335DS from the wall mount? Normally the TV will simply lift off, but in the 335, it fits into a recess in the wall and there isn't much clearance. it won't come off easily and I don't want to force it for fear that something will break.
selsesser is offline   Reply With Quote
Old 07-05-2015, 03:08 PM   #2
xman123's Avatar
i looked at mine and to me it looks like they stuck the tv on a mount then screwed it to the wall. so from what i can see unscrew it then pull whole thing out...
xman123 is offline   Reply With Quote
Old 07-05-2015, 06:14 PM   #3
That is the way. You have to remove all the screws and lift it out. It takes two people. I removed mine to add Apple TV and a HDMI cord.
Kevin and Betsy
2014 FR Georgetown 335DS
Bevkev is offline   Reply With Quote
Old 07-07-2015, 02:43 PM   #4
Yes there about 8 little screws that hold it to the wall, 4 on the top and 4 on the bottom of the TV. I took that bracket off and replaced it with a mounting rail that has straps the let you unhook it and remove the TV with a lot less hassle. I scratched the wood finish taking it out the first time, the bottom of the rail rubbed against the woodwork at the bottom of the TV. Suggest you have another person there with you to help if and when you ever take it out.
DuncanM is offline   Reply With Quote
