Old 11-01-2010, 07:00 AM   #11
yvesm's Avatar
I use a teflon filled pipe joint compound and teflon tape.
2013 Prime Time 230 FBS
Days camped in 2013: April to November
Days camped in 2014...about 40
Days camped in 2015...more than 2014!!
yvesm is offline   Reply With Quote
Old 11-02-2010, 09:48 AM   #12
jmduc's Avatar
Just did my winterizing on our 2011 Georgetown 374 and it is a 1- 1/6" and use teflon tape for sure.
jmduc is offline   Reply With Quote
Old 11-17-2010, 10:58 AM   #13
Bama Rambler, your right every one I seen, (both that I had) Suburban, were 1-1/16" and they don't thread in very far so are easy for someone who dosen't know better to over tighten.
370xl is offline   Reply With Quote
Old 11-17-2010, 12:21 PM   #14
Herk7769's Avatar
BIG CAUTION using any "Break Free" type solvent on the anode.
You really do not want that stuff in your potable water.
Hard to keep it out of the potable water once it gets inside the heater.
HAM CALLSIGN - KC3FFW
Old 11-18-2010, 11:55 AM   #15
6 point Sockets are your friend.
12 point Sockets are not.
Nights camped in 2010 = 21 nights
2008 Chevy CCab 5.3L 4WD Z71
2008 FR Surveyor 291
Champion Genset
Slpybear, Mrs Slpybear, Three Cubs
slpybeartx is offline   Reply With Quote
Old 11-24-2010, 05:22 PM   #16
jsutherl's Avatar
Confirmed 1-1/16" socket, 6 inch extension and a breaker bar did the job great. Harbor Freight had a set of large sockets that included a 1-1/16" for $19.99
2008 Georgetown SE 350DS BunkHouse
jsutherl is offline   Reply With Quote
Old 11-29-2010, 07:48 PM   #17
mgargiullo's Avatar
I just pulled mine out tonight... and yeah my pants are wet. Make sure you step to the side as you break the seal.
At what point should I replace the anode? Most of it is intact, but the base near the threads is eaten about half way through.
I should add.. I know the manual says yearly, but how often do you do it.. when it hits 50%? 75%?
2017 GMC 3500 Denali HD
2010 Rockwood Signature 8316SS
mgargiullo is offline   Reply With Quote
Old 11-29-2010, 09:03 PM   #18
jimh's Avatar
if u have it out, i'd go ahead and put a new one in. u old one still has life but they aren't that expensive.
i just pulled mine for the first time sense i bought it in 2002. there is abt 25% still remaining.
once drained, i would go ahead and either reinstall or replace it now to keep unwelcomed guest from using ur water heater as a home.
i don't know if more than one type of metal is offered for the anode, but i would replace with the same metal.
jimh is offline   Reply With Quote
Old 11-29-2010, 10:35 PM   #19
Herk7769's Avatar
25% remaining is about right for replacement.
While the instruction manual says to replace it annually, That is WAY overkill in most water situations. It may be true if you use exceptionally "hard" water all the time.
Sounds like you have about 95% good so I would dry it off; put Teflon tape on it and screw it back in. Take care not to over tighten it. No torque setting is called for in the instructions; just tight enough (with the Teflon tape) to "not leak".
The instructions also state to "NEVER" use RV antifreeze in the water heater". Not only will it waste 6 gallons of antifreeze; but the antifreeze is corrosive to the anode. If you must use it in the heater (why I don't know) it says to pull the anode and replace it with a 3/4 inch pipe plug.
Old 11-29-2010, 10:38 PM   #20
Herk7769's Avatar
If you open the kitchen taps and the low point drains all the water will drain out including most of the water heater water. Then pull the anode to finish draining. Dry shoes here...
