Old 01-07-2015, 07:55 PM   #41
miked11272's Avatar
I believe a structural issue like this should be covered. I have started a complaint with the NHTSA which I am still waiting for them to edit the complaint.... they entered the information incorrect. Forest River doesn't want to take responsibility for the issues with my coach. Now it appears that the passengers side is starting to do the same thing. What's to say the bolts around the entire coach are not breaking??
miked11272 is offline   Reply With Quote
Old 01-08-2015, 08:31 AM   #42
Arvicru
I have a 2009 Georgetown GT and this started happening on the driver side. I took it to Crestview RV in Georgetown, Texas and they said it was under warranty due to it being a structural issue. They repaired the coach per Forest River. We drove to California during Christmas time and within 200 miles I started hearing squeaking and cracking and the driver side wall is now moving again. So back to Crestview we go and now they are saying it wasn't originally covered under warranty due to me being a second owner and the age of the coach. I don't understand how this is not a safety recall??
Brian & Patricia
Southern California
2009 Georgetown 350 TS
Arvicru is offline   Reply With Quote
Old 01-08-2015, 01:34 PM   #43
miked11272's Avatar
Every one that has had a problem with the bolts breaking should file a complaint with the NHTSA. They will investigate the problem and hopefully issue a recall.
Old 01-09-2015, 08:30 AM   #44
Arvicru
Can you tell me how to file a complaint with them. Mainly just the contact info.
Brian & Patricia
Southern California
Old 01-09-2015, 09:30 AM   #45
miked11272's Avatar
Georgetown side wall bolts sheared off- and a fix!
This is the link to file the complaint.
https://www-odi.nhtsa.dot.gov/Vehicl...nt/index.xhtml
Old 03-16-2015, 10:42 AM   #46
ME
sparks1032's Avatar
I think I'm going to need to do this just saw light next to wall and drivers front corner of floor! ADMINISTRATOR can we get what is needed for this and make a sticky! Bolt size type quantity then the need to square off front end? Anything I'm missing?
2008 Georgetown 350TS
sparks1032 is offline   Reply With Quote
Old 03-22-2015, 12:49 PM   #47
Arvicru
Does anybody have April Connor's contact information?
Brian & Patricia
Southern California
Old 03-31-2015, 09:23 PM   #48
Retired Ford Tech
Is there any more developments with the side wall issues? The thread has been quiet. Are they any complaints with the new units and has FR responded to any past issues with the wall ?
rvpezzano is offline   Reply With Quote
Old 04-22-2015, 01:59 PM   #49
New member, first post. 2008 Georgetown purchased new in 2010. I have experienced the side wall bolt shear on our Georgetown also. I read with interest all the previous posts. Long story short, had a nerve racking slow trip home with the right front wall moving and a opening to the road letting cold air in, I checked the left side and found a few loose screws and one broken. Contacted FR and in process to get a resolution to the problem. Have also filed a complaint with NHTSA.
The post from ERIC52 is a very good repair. The screws used by FR seem awful small for the job.
Will let you know how it works out.
campdoc is offline   Reply With Quote
Old 05-04-2015, 07:52 PM   #50
Well it has finally happened. Driver side has come loose. Bad news is I am on way to Ak. for the summer. Hope it will hold till I get to Ak. Do not know what to do about it yet as I have no place to work on it.One question. How do you remove the molding to get at the screws pry it off or slide it off??? Any constructive help would be greatly appreciated. will be out of touch for the next week on the Alcan should be in Anchorage around 5/10
loryray is offline   Reply With Quote
