Old 05-04-2015, 07:35 PM   #51
Side wall trim removal
Sorry to hear you have the same issue with the screws shearing Loryray.
The side trim center piece just lifts out. Start with a small screwdriver and just pull it off. It will slip back into place when needed. Under the that small piece of trim you will find several screws holding the 2" trim piece on the side. remove the screws and pull it loose from the side. you will find sealing tape under it and under the sealing tape you will see the large headed screws. using a screwdriver try turning them. They are suppose to be tight. If loose they are broken if they will not tighten up. My wall dropped one inch.
The NHTSA web site is as follows
https://www-odi.nhtsa.dot.gov/Vehicl...nt/index.xhtml.
campdoc is offline   Reply With Quote
Old 06-10-2015, 03:29 PM   #52
waiter21's Avatar
I may have this same problem on my 2001 Mirada. I notice the drivers side wall can move 1/2 inch vertically. The dash stays still and the left wall can move up and down about 1/2 inch.
The right side seems OK, only the drivers side.
I'll be looking into this. thanks for the thread.
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 06-15-2015, 07:13 PM   #53
waiter21's Avatar
FYI - My Mirada suffered the same problem, but its design is a little different and was a lot easier to fix.
Emergency Exterior Wall Repair | 2001 Coachmen Mirada 300QB
Old 07-04-2015, 10:08 AM   #54
Side walls
Did Fr fix the problem got the newer say 2012 and up??
Don
Donlock is offline   Reply With Quote
Old 07-09-2015, 11:17 AM   #55
I would be curious as to if this was fixed on the newer units. I am fixing to pull the trigger on a 364TS but I am kind of apprehensive now after reading many of the problems people are having with the quality of the coaches.
av8erdunn is offline   Reply With Quote
Old 07-13-2015, 06:49 AM   #56
Anyone have an update on this issue? Have they fixed it on the newer models?
Old 07-13-2015, 07:33 AM   #57
Wow is all I can say. I guess this is our new class of engineers!
harderd is offline   Reply With Quote
Old 07-14-2015, 01:09 PM   #58
2008 Georgetown 350ts SE. Just returned from a 2000 mile trip from Michigan to Virginia's east shore and back. Had a squeak near my left foot that progressively got worse during the trip. I could feel about a 1/4" of give in the floor when my bare foot was touching the joint of the floor and the wall near the squeak. When I got home I pulled the exterior trim off the outside below the drivers window. I have Four 1/4 x20 screws attaching the wall to the floor behind that strip. Front 2 were sheared off. I replaced them with new screws of the same size. Squeak and movement is completely gone. Took about 10 minutes to do and about $1.00 for the screws. We'll see how long it lasts. Doing a short 300 mile trip this weekend to northern Michigan. I completely realize the OP's fix is sturdier but I was willing to try the simply before I took the extreme approach. I'll circle back and let you know how it holds up.
bbrinks is offline   Reply With Quote
Old 07-24-2015, 10:25 AM   #59
Cool 2nd owner, looking for Other than Collision to cover this.
Have Windsong 2001 349S in process now as 2nd owner and will not let this go if my National General Claim with Other than Collision rider does not cover it as the entire frame section metal broke into several pieces. Will post my comments on the last of this post thread..
djmathat is offline   Reply With Quote
Old 07-24-2015, 11:21 AM   #60
Unhappy Windsong 349s frame breaking and sidewall separation.
06-30-2015, 09:31 PM
djmathat
Sidewall separating from the floor
We have had our 2001 Windsong 329 for 4 yrs in August this year and have driven it and lived in it full time during that time driving throughout the USA, Canada and up to Alaska and back and are now in Illinois and have put over 31K on it. Previously the original owner had it 10 yrs. and drove it 26K during that time occasionally. We have had and still have the normal problems with this amount of use so ongoing. The repairs have been done religiously. But they are increasing in occurrences and I have a Good Sam extended warranty that has so far pretty much been more than useful for the repairs and replacements to systems and appliances we have needed.
However I now want to put a question to this forum....Has anyone had any problems with the side wall b4hind the passenger captainís chair separating from the floor of the coach, up to a inch and getting longer and wider depending on whether parked and leveled or driving down the road. It seems like the entire coach is shifting from side to side while going down the road and I do not drive over the speed limit and mostly stay at 50 to 55 on the interstates. Now that we have found this gap about 2 ft long I do not want to drive any further without some more information. I had a RV repairman look at it and he said he did not do body work but recommended I call a local body shop and that it must be an insurance claim problem and not warranty as the roads would have caused the separation damage while constant banging up and down the uneven surfaces???? Was going to call Forest River today and found the forum and decided to use it first. Next month I will officially not have any more payments on the coach and it is ours. I am not laughing, it should have been a great month but now am wondering if we need to consider purchasing another or repairing this big box that is 14 years old and the extended warranty will be up next May??? I am sure it would be a nice stay in one place for someone who wants to purchase it and just live in it but we are in Illinois and need to go back to the West Coast by winter and had planned to go north and then down past the Great Lakes and up into Maine and back through the fall color and across the middle of the states to reach California by the holidays and now am wondering if I should even leave this military Fam Camp park we are in for another week???
07-02-2015, 11:55 AM
KyDan
Bump-- anyone have any suggestions for this new member???
Peace!
Dan & Rita D
2004 5.3L Silverado 1500 ext. cab 2WD
Blue Ox WD hitch, AirLift load levelers
2013-41, 2014-31, 2015-13
07-02-2015, 01:10 PM
harderd
Perhaps some pictures and a better explanation. I can't picture in my mind what you are saying.
07-02-2015, 02:02 PM
B and B
Canadian Campers
OP, you are pretty close to Goshen Indiana. Might be worthwhile taking pictures and if determined roadworthy head over there. There are some subcontractors the FR uses like RV Specialties that might be able to assist and give you an idea on repairs. I did not notice anything searching on FR Forums on Windsong wall separation. It might be possible to find a mobile RV mechanic to fix the separation where you are at.
B and B
2013 Rockwood 8289 Diamond Edition 2014-50 Camped 2015-19 camped 30 booked
GY Marathon D's/2.5 inch lift kit/Powerhouse 4 KW EFI Generator
2015 Ford F 250 Lariat Power Stroke Diesel
2008 Golden Falcon 380PA Park Model Model 2014-35 Camped 2015-25 camped
"Oh Canada,True North Strong and Free!"
07-02-2015, 02:33 PM
Crockett
Id submit to insurance...could have been a frost heave in Alaska. Low miles and paid for..id keep but im cheap. either way it need repair. Due to age, I would worry about cosmetics too much. If insurance was a no go, I would try to get a good, functional, repair cheap. Fix it now and make it pretty later I always say...
Today, 12:09 AM
djmathat
Broken steel frame, clean break not sidewalls.
The discussion with Forest River to stop and take some time to get a good RV repair shop to evaluate the problem as the Georgetown rep said he might have a fix to discuss with a RV specialist. We had the park private business RV mechanic and repairman look at it and he discovered that the whole frame had broken clean through and dropped over itself where there were a couple of clean breaks in the steel framing and then it progressively caused the screws to break off or pull out and push the top of the coach out away from the flooring. Long story short this was submitted to our National General Insurance through Good Sam as an Other than Collision problem as it does not come under mechanical for the extended warranty. This coach has 57,000 miles on it and has been cared for by both the original owners and ourselves. I know there comes a time when one has to move on to another "home" but I just paid this coach off last month, was hoping to get a few months without any more payments. Never driven over 55 MPH it was remodeled with new flooring and furniture in Feb. 2013. The evaluation by Majestic Truck Collision Frame Repair has been done and they come highly recommended and they are wonderful to work with. It may take up to two weeks beyond our planned stop at Cutty's Camping and RV Resort in Grimes, IA and they have been very understanding to allow us to extend our Coast to Coast time so we do not have to go into a hotel until the coach is scheduled for the repair that will take up to 2 days maybe 3. The entire front right side of the coach back through the propane compartment has to have new angle iron and steel attached and be reset and the coach have new steel welded and re-screwed to the frame of the chassis of the coach. There is no water damage or any indication of mold or rust or anything but clean wood and metal as the breaks are clean and fresh and the under-side of the chassis is tight and sturdy and without any play on the suspension, differential and other parts.
NOW my question is; has anyone of you ever experienced or know about coaches steel frames that connects to the chassis break and push and pull out the screws along the side of the coach and the the coach wall and frame drop slightly and separate from the floors??? (I have a friend who has spent 11 years full-time and their first 35 ft Coachman had the problem and it was fixed under the Other than Collision clause on their policy. Not heard of very often supposedly?
The adjuster suggested that this may be normal wear and tear and not covered under Other than Collision and when asked what that meant she said it meant like hail or flooding. I asked her if potholes on the highways were Other than Collision or Collision as there have been so many of those that could not be avoided due to traffic configurations the steel frame problem could have snapped and finally broke more to the point it is now visible???
Well she has all the pictures and estimate for repairs and it will be a week until they can decide if the repair shop can do the work under insurance coverage or if they will deny it's not covered? Many of you have been here with issues I'm sure . It is just so difficult to think that you pay and pay and pay to cover all of the possible problems with your motorhome and then find out that there are other things they may be able to squeeze out from under to repair at actually your cost that you pay for many times over while owning the coach. Insurance poor and I am hoping against hope they will be willing to honor what appeared to be coverage for this type of breakdown. Any suggestions or comments are most welcome.
Today, 08:59 AM
harderd
There is a thread on Georgetowns separating. Search for it, quite informative. Attached with sheet metal screws, fixed with bolts.
