Old 11-23-2010, 12:13 PM   #1
Hydralic pump
I have a 2007 georgetown with Ford v-10.Could someone be so kind and tell me where the hydralic tank is.
toolmangj is offline   Reply With Quote
Old 11-23-2010, 03:33 PM   #2
kvtaylor's Avatar
We have a 2008 Georgetown 378 and ours is located in a inclosed box in the third compartment on the drivers side of the coach. it can be accessed by removing the screw holding the door closed at the top of the door. your tank and pump is located inside. It should be kept at a level 1 inch from the top of the tank when all of the slides are in and the jacks are up.
Ken and Velda
Dahlgren, VA.
2008 Georgetown XL 378
2010 Ford Escape Limited
kvtaylor is offline   Reply With Quote
Old 11-23-2010, 04:46 PM   #3
CLASS "A" Senior Member
cfsoistman's Avatar
The box is covered with a grey carpet. There should be one screw holding it closed.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
cfsoistman is online now   Reply With Quote
Old 11-23-2010, 06:12 PM   #4
Thank You !!
