Originally Posted by Wantoby
Okay, thank you to all of you! I am all alone so I guess I will retract a bit and check and retract a bit and check. How full when retracted? Do I use transmission fluid?
Full should be about on the top line, should be several lines on the tank. I run just below the top line, which is about 3/4 full on the tank. And yes, as I said before ATF, i.e., automatic transmission fluid to non gear hearts. What I'd do personally if by mysel:
If your not set up check the tank to the fill line and you should be good to go.
If set up, and slides and jacks deployed make sure the tank isn't over full, should be close to the bottom line. Retract away, if over full it will blow it out the overflow onto the ground or do the smart thing and run a slide in, check, run next slide, check, etc. if the tank is full drain some off or it will blow out the overflow.
