Old 04-15-2011, 10:54 AM   #11
SoMoney's Avatar
Originally Posted by donn View Post
Plastic tank? Take a wrench ans snug up the bolts holding the tank to the pump. That should take care of your problem.
I recently took delivery of a 2010 GT 320DS. Spotted some drippings under the coach and sure enough, HYDRAULIC FLUID leaking from the plastic Lippert reservoir .. PICS BELLOW....
The Tank to Pump looks dry on mine.. Im not sure were this is coming from unless those tray screws near the back of the tank piereced the reservoir
ID:	5303   Click image for larger version
SoMoney is offline   Reply With Quote
Old 04-15-2011, 10:54 PM   #12
Originally Posted by condo
I have 2010 Georgetown 373 and also have a hydraulic leak. The return lines on the Lippert hydraulic system are orange and have blistered and one to a rear jack is leaking. Lippert says Forest River installed the lines. The repair shop I have it at says it's a lower pressure line and should have the higher pressure black hoses on both the supply and return. The rig is out of warrenty and I'm currently trying to get Forest River to cover the repairs.
had the same problem just had them replace with rubber lines and new ends they tried to just fix the ends but had a big bubble about to burst so the just replace with rubber hoses.
mccorklera is offline   Reply With Quote
Old 04-20-2011, 09:29 AM   #13
SoMoney's Avatar
Mine looks okay. I crawled up on top of it and it looks to be an over filled res.
ID:	5373   Click image for larger version
