Old 04-28-2016, 12:55 PM   #1
Exclamation Hydraulic problems
While camping in Bristol Tenn. I was leveling the motorhome when I heard a loud noise under the unit. I got out and found that the entire hydraulic assembly on the drivers side rear had broken loose from the frame and hanging by the hydraulic hoses. The weld consisted of 4 tack welds that hadn't even penetrated the metal of the arm or frame. We have a 2016 378TS XL. IN CHECKING, NONE OF THE HYDRAULICS HAD anything more than the same four tack welds
Just wanted to make everyone aware of a potential problem.:Head BangingonComput
Wesley1249 is offline   Reply With Quote
hydraulic
