Old 07-27-2014, 09:29 PM   #1
Smile Hydraulic Pump Inop for Jacks/Slides
Found out in addition to the 50 Amp circuit breaker, that there is a 15 Amp fuse in the pump/fluid tank area of a 2009 350TS that will shut the whole system down if it blows or comes loose. Thought I would pass along the info in case you may experience the problem I had last week.
SnowBird9 is offline   Reply With Quote
Old 07-28-2014, 02:14 AM   #2
Cornelius's Avatar
There are also two fuses in the black metal solenoid box above the deep cycle batteries that are part of the hydraulic pump control circuit.
2010 Georgetown 373
2013 Jeep Wrangler
Cornelius is offline   Reply With Quote
hydraulic, jacks, pump, slide, slide out
