Old 03-02-2014, 03:18 PM   #1
2003 Georgetown 325
Hydraulic Reservoir
OK; I have a 2003 Georgetown 325 and am wondering where they have put the hydraulic reservoir in it . I wanted to check fluid levels and couldn't find the reservoir.
Any suggestions?
reddiver is offline   Reply With Quote
Old 03-03-2014, 09:16 AM   #2
bend302's Avatar
First, this should have been a PDI item.
Mine (Older version 2005) is behind a panel in a compartment on the driver side near the front. That's where the hydraulic pump, etc. is.
Bill
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
bend302 is offline   Reply With Quote
Old 03-03-2014, 11:51 AM   #3
SKnight's Avatar
Do something to run the pump and follow the noise it makes. The reservoir should be part of the pump or very near it.
Check it with all cylinders closed up. That will put the fluid at it's highest level so you can check it. If you don't close all the cylinders first, set the fluid level to spec then when you close the cylinders then you'll have fluid everywhere.
Typically, when it's set to travel, slides in, etc, is when the cylinders are closed.
hydraulic
