Old 12-17-2015, 04:45 PM   #1
Hydraulic reservoir
Whose bright idea was it to put the hydraulic resivor for the jacks and slides under the motorhome behind the LP tank. Mine was about a quart low from the factory and I had to crawl under the motorhome and use a long funnel attached straight to the quart bottle to fill it. This required sitting up between the frame rails with a flashlight in my mouth and trying not to spill any while blindly pouring in the fluid. I would have to bet that it was designed by some whiz kid engineer that has never been in a motorhome. Lol
georgew48 is offline   Reply With Quote
Old 12-17-2015, 04:55 PM   #2
What year and model do you have so others may know.
Old 12-17-2015, 04:59 PM   #3
2015 Georgetown XL 377TS.
Old 12-18-2015, 01:05 AM   #4
2007 WildCat 32QBBS
18CrewDually's Avatar
At least you'll only have to do it once. As long as there's no leaks of course. I have a hand pump and long clear hose for remote reservoirs.
18CrewDually is offline   Reply With Quote
Old 12-20-2015, 07:07 PM   #5
Coach 350's Avatar
2012- 350ts Georgetown.
Have same situation. Installing the fluid in a Space shuttle is probably easier
Coach 350 is offline   Reply With Quote
Old 12-20-2015, 10:48 PM   #6
Assenmacher Tools makes a container with a hand pump, a little pricey, but better than pouring blind.
http://www.amazon.com/dp/B007QV2X2O/...I28PXXO27UVYXA
nicholsonv is offline   Reply With Quote
Old 12-21-2015, 06:37 AM   #7
I am thinking that a hand pump that screws onto a quart bottle might work. They have the for pumping lower case oil in I/O boat engines.
Georgetown XL 377TS
USAF-- CMSGT Retired.
Old 12-21-2015, 07:06 AM   #8
Guess it is model dependent. In my 335DS it is easy to reach through the basement battery door. I am not that familiar with your coach but it would seem that the cause may be the "pass through" storage compartments. On mine all of the drivers side compartments, with the exception of the large pass through in the rear are for maintenance access (propane, batteries and hydraulics, generator and water and sewage.) These coaches are complicated and sometimes its hard to make everything line up for easy access without sacrificing something. As others have said, at least you don't have to do much for regular maintenance on the levelers and it sounds like a decent compromise by favoring storage over access to the levelers.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 12-21-2015, 07:30 AM   #9
lgray's Avatar
lgray is offline   Reply With Quote
Old 12-21-2015, 03:04 PM   #10
Must have changed from the old ones, my 2007 has it in its own basement compartment, you could take the whole thing out in about an hour
Carmen is offline   Reply With Quote
Old 12-22-2015, 03:18 PM   #11
I do it the same way. Crawl under and then sit up between the framing. I use a headband flash light so I have both hands free. Not too bad compared to trying to add oil to the engine and brake fluid to the brake reservoir. Ug!
2015 Georgetown 351DS
JohnGalt1061 is offline   Reply With Quote
hydraulic
