Old 03-09-2015, 08:01 PM   #11
2012 Solera
2 amps for 24 hours is only 48 amp-hours. Typical MH house battery setup is two size 27 12 volt deep discharge batteries, about 200 amp-hours. If batteries were "dead", would take four to five days with that charger to recharge them. 12.2 volts is quite low and may be consistent with the 24 hours you have charged them. Note other battery configurations like two or four 6 volt batteries would take longer to recharge.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 03-09-2015, 08:31 PM   #12
Right. So it may just need another 2-3 days to be fully charged and operate the slides.
blnbooty is offline   Reply With Quote
Old 03-09-2015, 08:42 PM   #13
2012 Solera
If you are plugged into shore power and your batteries are reading 12.2 volts, your converter is not working. Tripped converter circuit breaker? The converter should charge your batteries much faster than the 2 amperes from your external charger.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 03-10-2015, 12:26 AM   #14
jergeod's Avatar
I agree the converter is not charging if it was you should be reading 12.6 to 13.2 volts. Make sure that where you have the coach plugged in that it is live first, if so check your breakers, if there is power to the converter then bad converter.
George & Jerri
06 GT 340 TSSE
USMC
jergeod is offline   Reply With Quote
Old 03-13-2015, 06:34 PM   #15
Finally found the problem. Trombetta. Reversed the slide motor. Click image for larger version
Name:	ImageUploadedByForest River Forums1426289613.212305.jpg
ID:	71259Click image for larger version
Name:	ImageUploadedByForest River Forums1426289634.828476.jpg
Old 03-13-2015, 06:34 PM   #16
Thanks for your help
hydraulic, slide
