Old 04-02-2011, 05:40 PM   #1
I am an idiot I guess
Took my coach batteries out now I can not remember how the wiring went
2006 georgetown 378ts - baterries under steps side by side
I can not remember how the additional wires went on - 1 blue - 1 white - 1 green
Can anyone help
timbo8819 is offline   Reply With Quote
Old 04-02-2011, 06:07 PM   #2
tmmar's Avatar
Can't help you with your question but wanted to welcome you to the forums!! I'm sure that someone here will be able to help you.
Tom and Margaret
2014 Berkshire 390bh-60
Old 04-02-2011, 06:10 PM   #3
Thanks good to find this
Old 04-02-2011, 08:30 PM   #4
Battery Connections
I'm not sure this will be of any help but attached is a photo of
my 2009 - 378 battery compartment.
Hope this helps
Gary
mbtelguy is offline   Reply With Quote
Old 04-02-2011, 09:06 PM   #5
That works thanks a bunch
Old 04-02-2011, 09:23 PM   #6
DJW
DJW's Avatar
Red wires should go to the post marked w/+
black wires go post marked w/ -
+ stands for positive
- stands for negative
make sure you check this / or you can damage batterys / and get hurt
DJW is offline   Reply With Quote
Old 04-02-2011, 09:39 PM   #7
Gotcha but it was not the main wires I was confused on there are three smaller wires white-green -blue that also connect - the pict above looks correct or similar - I would have thought however white would be positive instead of negative but i will give that config a shot
Old 04-02-2011, 10:16 PM   #8
jsutherl's Avatar
Here are pictures of how my batteries looked before I installed the new ones. I took these so I'd know how to reconnect the wires when I put in the new batteries.
Also I attached a much clearer picture of the new battery install. It was taken with a much better camera and you can clearly see where all those little accessory wires go.
ID:	5140   Click image for larger version
ID:	5141   Click image for larger version
ID:	5142   Click image for larger version
2008 Georgetown SE 350DS BunkHouse
jsutherl is offline   Reply With Quote
Old 04-03-2011, 06:20 PM   #9
w6st411's Avatar
The blue and green wires are the hot leads for the fridge and propane sensor.
w6st411 is offline   Reply With Quote
Old 04-03-2011, 06:56 PM   #10
I was told by my RV dealer that on RVs, white is usually ground, FWIW.
caleb is offline   Reply With Quote
