Old 07-27-2015, 12:14 PM   #11
RudysWorld's Avatar
I was having problem with alarm and checked and alarm unit is expired, I was going to try replacing it.
Rudy - 10 year old long haired dachshund, RIP
2011 Georgetown 350TS
2013 Chevrolet Equinox toad
RudysWorld is offline   Reply With Quote
Old 07-27-2015, 02:09 PM   #12
Our steps were manufactured with rivets. So far we have lost 3 which I have replaced with bolts and nylock nuts. This is with 215 camping nights of use. Our older camper had stair bolts breaking too.
2013 Flagstaff 8528IKWS, 2006 F-350 6.0L
DickiedooFlagman is offline   Reply With Quote
Old 07-27-2015, 07:29 PM   #13
Newellri's Avatar
Rudy; is there a date marker on the unit? Thanks
Newellri is offline   Reply With Quote
Old 07-27-2015, 09:32 PM   #14
RudysWorld's Avatar
Yes mine has an expiration date on the face of the alarm.
Old 07-28-2015, 09:52 AM   #15
Newellri's Avatar
Thanks Rudy I will check.
Old 07-29-2015, 05:38 PM   #16
Newellri's Avatar
Up date on propane alarm. While checking all fittings with soap I found a very small leak, fixed it and all seams well for now.
Old 07-31-2015, 10:20 PM   #17
Newellri's Avatar
Next day and the alarm going off while washing! Ugh! Today went off again, put fan on it and it quits. I am beginning to think the sensor has reached its life span. It is about 52 months old and the front says replace before 60 months.
Old 08-01-2015, 11:03 PM   #18
I had to replace the alarm after 36months. I also have the King Jack which directly relaced the Winegard. Works great and I get lots more local channels.
John & Susan, Olivia the dachshund
2011 Georgetown 337DS
2003 Dodge Dakota
Hampton Roads VA
2016 174 Days camping, 2017 66 days 2018 13 days
mogman is offline   Reply With Quote
Old 08-02-2015, 06:53 AM   #19
Newellri's Avatar
Thanks I think I will just replace the sensor. It is going off in the afternoon heat now just sitting a home. If I put a fan on it it will return to normal.
Old 08-02-2015, 08:24 AM   #20
Newellri's Avatar
Mogman did you replace the crank up or mount to the crank up. I know they make both styles. I want to get rid of the crank up as it rattles while on the road. Thanks
