Old 07-26-2015, 04:15 PM   #1
Newellri's Avatar
I have a couple of questions, I have a GT 350 ts it is a 2012 but built in June 2011.
Just wondering what are the symptoms of a failed sensor. The second question is has anyone replaced the bolts on your steps?
I had one break last winter in TX, I replaced with a common grade 8 bolt but It feels very sloppy. I wonder if It is a shoulder bolt.
Last has any one replaced their crank up antenna with a king jack? Any problems and where did you the 12 volt.
Newellri is offline   Reply With Quote
Old 07-26-2015, 04:18 PM   #2
Newellri's Avatar
Sorry it missed the first line. The propane sensor is going off. I shut off propane at the tank yesterday that stopped it but today it is going off again with the propane shut off!
Old 07-26-2015, 04:20 PM   #3
Newellri's Avatar
Thanks for help!
Old 07-26-2015, 05:18 PM   #4
Very common for the center bolt to break. My steps were only 6 months old and it snapped. Couldn't be replace because it was welded in place which ruined the nut. The step manufacturer (LCI) ended up shipping me a new set of steps. This is a common problems with these steps. You can search the forum and read what others said about them. I have never cared for my steps, too flimsy and wobbly.
2013 Georgetown XL 378
2008 Honda CR-V
wrapperman is online now   Reply With Quote
Old 07-26-2015, 08:01 PM   #5
Tim & Lisa Trempert
It's likely your batteries are boiling causing the alarm to go off. Feel your batteries and see if they are more than just slightly warm. If so, you probably need new batteries. Your can also test this theory by turning off the battery disconnect so your batteries don't charged while you are plugged in.
Tim & Lisa
2011 Georgetown 350
Trempert is offline   Reply With Quote
Old 07-26-2015, 08:07 PM   #6
Tim & Lisa Trempert
Buy the exact bolts on line. Both the center bolt and the bolts for the side of the stairs. They are special shoulder bolts and using anything else will cause the stairs to be wobbly and could cause further damage.
Tim & Lisa
2011 Georgetown 350
Old 07-26-2015, 10:26 PM   #7
Newellri's Avatar
The batteries have been replaced with sealed units, this solved the early problems with the co2 propane dector.
Old 07-26-2015, 10:27 PM   #8
Newellri's Avatar
Where did you find them on line? Thanks
Old 07-27-2015, 06:05 AM   #9
abjb's Avatar
King (Jack) makes a replacement antenna, easy swap AND IT WORKS!
Amazon.com: KING JACK OA8000 KING JACK(TM) Amplified Digital HDTV Antenna: Electronics
Here's a link to Lippert replacement parts.
RV Steps, Step Accessories and Replacement Parts
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
Old 07-27-2015, 07:21 AM   #10
Coach 350's Avatar
Have same coach. Had the steps replaced with Kwikee steps. Lippert steps bolts sheared every year. Contact Forest River, they sent Kwikee steps to dealer and were replaced free of charge. My coach was under warranty at time.
Coach 350 is offline   Reply With Quote
