Old 07-26-2012, 12:18 PM   #1
tncruiser's Avatar
i have searched ,but no avail
okay folks here is an easy one?????????
where is the fuse for the antenna amplifier/bat boost/in house radio use
i assume they are all on the same circuit as everything else works
brianj
liven life in east TN and wherever my
2011georgetown280ve, and
2016 fordexplorer and hemi RAM
take us
tncruiser is offline   Reply With Quote
Old 07-26-2012, 01:20 PM   #2
KyDan's Avatar
When I replaced my Concertone unit a couple years ago I found an inline fuse on
the back side of the unit.
If you don't get a better answer you might have to pull the unit out of the
wall/cabinet and look in back.
Good luck!
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 07-26-2012, 01:27 PM   #3
IT Guru
Send a message via AIM to jsilvius Send a message via Skype™ to jsilvius
+1 this. I was very, very, very p.o. when I had to take it into the shop because it wasn't working and they told me it was just a fuse, and when I asked where the dang fuse was because it wasn't in my panel, they said "in-line fuse". I about blew my top.
2006 Flagstaff 831FKSS
2005 Dodge Ram 2500 SLT 5.9L Turbo Diesel Quad Cab
1 - DH (me); 1 - DW (Tee); 1 - DS (Jarod, 12)
Nights Camping: 2010 - 15; 2011 - 7; 2012 - 9
jsilvius is offline   Reply With Quote
Old 07-26-2012, 02:56 PM   #4
Freds342's Avatar
Not that it helps much, but I don't think I've ever seen an aftermarket or RV dash radio that didn't use an in-line fuse.
2005 Georgetown 342DS XL, Full Banks Package
2005 Liberty Renegade 4X Toad
1989 Wrangler Sahara Toad
1984 19.5' Beachcraft i/o 5.o liter, 4-bbl (and you thought your Moho sucked gas!)
D/W Carole and Maggie the Teacup Lab (Black Chihuahua)
Freds342 is offline   Reply With Quote
Old 07-26-2012, 03:45 PM   #5
Iggy's Avatar
brianj
Don't know in your rig but this is what I would do.
1. I would check the inline fuses in the motohome battery compartment. Look for a green or blue fuse holder. May be 15 amp or larger.
2. Check the DC 12 Volt fuse panel for the motrohome. Mine is located next to my 120 volt panel. Check with a meter ALL fuses.
3. Check under the dash panel, left of the steering wheel on the firewall. Check all fuses.
4. If you still can't find you will need to get behind the ash radio and see if you have any inline fuses blown.
That is the best I can suggest without coming over to your house.
Here are a few pictures that may help
Name:	April 26 2012 043.jpg
ID:	17059   Click image for larger version
ID:	17060   Click image for larger version
ID:	17061   Click image for larger version
Iggy is online now   Reply With Quote
Old 07-27-2012, 07:10 AM   #6
tncruiser's Avatar
Here are a few pictures that may help[/QUOTE]
come on over the coffee is made
i checked the fuses in the bat compartment am hoping the fuse is not in the block at the floor as my 225# old body is hard to get down there
but since you can with a camera i have to ask how do you take your coffee
thanks
brianj
take us
Old 07-27-2012, 09:42 AM   #7
lindy's Avatar
While mines a TT the fuze for my antenna booster/amp was in the fuze panel at the main circuit breaker/fuze box located on the front of the 120V-12V converter? box, the main elect box for the whole trl.
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
lindy is offline   Reply With Quote
