Old 02-29-2016, 06:33 AM   #1
I must be missing something
We have a 2013 378xl did they come with a inverter or was that an extra cause I cannot find it. Also we have nothing 110 v work without genset. Or shore power on just askin'
rwehba is offline   Reply With Quote
Old 02-29-2016, 06:44 AM   #2
TURBS's Avatar
Do you have a residential fridge?
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 02-29-2016, 06:47 AM   #3
Yes we do
Old 02-29-2016, 06:58 AM   #4
TURBS's Avatar
Hopefully someone can help you locate it!
2015 Columbus 320RS
2008 2500HD Duramax
Old 02-29-2016, 07:05 AM   #5
bubbles's Avatar
[QUOTE=rwehba;1115662]We have a 2013 378xl did they come with a inverter or was that an extra cause I cannot find it. Also we have nothing 110 v work without genset. Or shore power on just askin'
I believe your inverter is dedicated to the residential fridge operation. There may be only one or two AC sockets tied to it also.
Old 02-29-2016, 07:09 AM   #6
Originally Posted by rwehba View Post
Yes we do
Will the Refer.work on 12V,or is it dead also? Youroo!!
Old 02-29-2016, 08:13 AM   #7
bubbles's Avatar
It's a residential fridge.
Old 02-29-2016, 08:20 AM   #8
I know it is a Res Frig.I am asking if IT runs on BATTERY power even if the Micro or TV will Not Run! Youroo!!
Old 02-29-2016, 08:32 AM   #9
wmtire's Avatar
I'm with Bubbles here and don't understand your question as stated. If it's a residential fridge, it doesn't run off 12 volt directly, but would have to have an inverter changing the 12 volt DC to 120 volt AC.
Are you perhaps asking if it's currently running off of battery power ONCE it goes thru an inverter?
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 02-29-2016, 08:41 AM   #10
If it is a residential fridge you need to have a charged battery for the inverter to change 12v dc to 110v ac. The inverter should be very close to the battery. Usually only for the fridge but yours may be different.
shortkid is offline   Reply With Quote
