Old 03-11-2013, 07:49 PM   #11
VinceU's Avatar
Originally Posted by Aandchart View Post
In my photo, you can see the leak. I snapped a quick shot then turned it off.
For sure its worth to get it working, I've mades pounds and pounds of ice with mine, pretty efficient for such a small machine.
Old 03-11-2013, 08:06 PM   #12
Send a message via Skype™ to Falcon35
I think your right, you will have to pull the foil of and then you'll see a big split.
Watch out for the heater wire. When the tech put mine on he ripped a lot of the foil. I plan to make sure that I replaced that and put some more insulation around it before I get somewhere it may get close to freezing.
2012 Georgetown 378TS Fire Mist
2008 Honda Fit
ReadyBrake™ Surge Brake System integrated with ReadyBrute™ Elite RV Tow Bar
Protect-A-Tow
Falcon35 is offline   Reply With Quote
Old 03-11-2013, 08:20 PM   #13
Aandchart's Avatar
Thanks for the tips. I though maybe the brass nut and the brass ball seal needed a rubber seal. But it still leaked regardless. It's coming from the valve somewhere.
I'm sure it is warranted, but the dealer is eight hours away, and the local place said it wasn't worth there time to do warranty repairs.
I'll add this to the list of things needing fixed, next to the leaky hydraulic system.
Aandchart is offline   Reply With Quote
Old 03-12-2013, 06:15 PM   #14
Just a suggestion, but your owners manual on the fridge should have instructions on how to winterize the ice maker. Follow that procedure which should include using an air compressor on the valve to blow out the valve and water line. This procedure forces the valve to " cycle" through as if making ice. Perhaps the valve is stuck or clogged.
sherman12
2011 Georgetown 330TS
Kia Sportage on MasterTow Dolly
sherman12 is offline   Reply With Quote
Old 05-26-2016, 03:12 PM   #15
Originally Posted by sandpiper View Post
My 2012 378 go to the outside and pull of the cover on the back side of your refrigerator there is off/on push/pull switch follow your water line you should find it and make sure the arm on the ice maker is down to make ice
I have a 2016 sandpiper 378... but I have a home refrigerator. I dont believe there is an outside door for it. any other ideas on where I need to check?
Thomasnobles is offline   Reply With Quote
Old 05-29-2016, 11:28 AM   #16
VinceU's Avatar
If there is no outside access (not always fitted). You may need to pull the box in. Check for braces top and bottom. Power cord and feed tubing will have enough length.
