Old 04-07-2014, 09:12 PM   #1
Sbryant's Avatar
Improvements on GT360XL
Lowered clothes rod in closet - was too high & I hated the slotted factory rod.
Name:	ImageUploadedByForest River Forums1396921343.999044.jpg
Took out the pantry bracket & baskets and replaced with homemade drawers.
Name:	ImageUploadedByForest River Forums1396921507.367016.jpg
Made shelf behind couch for DW that also includes a 120V receptacle so she can charge her phone while still using it.Click image for larger version
Name:	ImageUploadedByForest River Forums1396921732.467283.jpg
Fixed my driver's chair so that I can turn it around.
Name:	ImageUploadedByForest River Forums1396921862.633694.jpg
Added a receptacle next driver's chair while it's turned around for my use.
Name:	ImageUploadedByForest River Forums1396922018.880452.jpg
Added a screen door opener lever so I can open it having to slide the little door back and forth.
Name:	ImageUploadedByForest River Forums1396922236.565872.jpg
Added a chain to the screen door lever so DW don't have to reach so high.
Name:	ImageUploadedByForest River Forums1396922416.924842.jpg
Hated the "high" awning where I had to use a ladder to adjust it down, so with stiff wire and a bungie, I reach up, hook the wire, and, using the bungie, pull the awning down & then attach the bungie to the wall.
Name:	ImageUploadedByForest River Forums1396922733.504237.jpg
Made the door open wider by moving ten rod bracket in about an inch.
Name:	ImageUploadedByForest River Forums1396922888.798061.jpg
Covered the "naked" slot for the stove covers with black-colored tape to improve looks.
Name:	ImageUploadedByForest River Forums1396923039.966654.jpg
Installed TV remote holders.
Name:	ImageUploadedByForest River Forums1396923131.090699.jpg
Sbryant is offline   Reply With Quote
Old 04-08-2014, 06:30 AM   #2
Wow, you've been busy. All great mods.
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
alparmer is offline   Reply With Quote
Old 04-09-2014, 07:19 AM   #3
How'd you get the drivers chair to turn around?
Did you re-bolt it to the floor? Safety concerns?
Paul and Rosemary
2011 Georgetown 378 Firemist
2010 Jeep Liberty Limited 4X4
Maddog378 is offline   Reply With Quote
Old 04-09-2014, 08:16 AM   #4
Sbryant's Avatar
I just "had" to make the driver's chair turn around to use, so I removed 3 of the bolts (2 rear & right front) where the chair bolts to the turning part.
This lets me swing the rear of chair away from the steering wheel and turn it around.
This is not dangerous because the seat belt attaches to the turning part.
Old 04-09-2014, 08:23 AM   #5
Great looking mods!
Old 04-10-2014, 11:40 AM   #6
Krazymace's Avatar
Interesting. We've never had a problem with either seat. My wife figured it out. Pulls a bottom flap and releases something under the seat. We struggled for awhile until she figured it out. FR provides no instructions, like most everything else.
Krazymace is offline   Reply With Quote
Old 04-23-2014, 05:16 PM   #7
intercept's Avatar
Lower the seat
Tilt the wheel forward
Tilt the seat back forward
Slide the seat as far toward the steering wheel as possible.
Rotate the seat
Some seats also need the seat bottom to tilt forward too
This is for a power drivers seat
2012 Georgetown 378XL
Toad 07 Lexus RX350
intercept is offline   Reply With Quote
Old 04-23-2014, 05:20 PM   #8
intercept's Avatar
Do you have a part number off of the door closer?
Toad 07 Lexus RX350
Old 04-23-2014, 07:48 PM   #9
Sbryant's Avatar
Glad you asked - the gas filled rod at the bottom of the door actually opens the door instead of closing it. Here is the info:
Mfg: IGC (Industrial Gas Spring)
Model: 89Z100211XX0067
Specs: 15 lbs pressure, 13" closed, 20" open
Their phone 815-553-0253 Romeoville, IL
The other device we use to open the screen door from inside is a small black plastic lever mounted on a grommet - I bought this at our local RV store.
