Old 07-06-2016, 11:18 AM   #1
Initial fridge cool down?
We hope to soon be the proud owners of a new 335DS. We've been camping for years having run the gamut from pop-up to large 5th wheel but have not had any experience with residential fridge on the road.
Now, there is no power available where we will store the RV so We are trying to figure out the easiest and most economical way of doing an initial cool down on the fridge.
I am assuming I could run the onboard generator overnight to accomplish this. I also have a Honda 1000 generator that I could use since it would probably consume far less gas (I assume). Are either of these unsafe? Anyone do this using the onboard generator and, if so, how much gas did you burn overnight (assuming you were not running the ACs).
Thanks,
Dave
DocData757 is offline   Reply With Quote
Old 07-06-2016, 11:41 AM   #2
chrisbailey13's Avatar
With The residential refrigerator, you should be able to run it off the inverter (the 335 should have one) which runs off the batteries without having to run the genset. an overnight run shouldn't cause too much of a drain on the batteries with the inverter.
based on the Literature for the Georgetown:
Stainless Steel Residential Package:
22.5 cu. ft. 110v Stainless Residential
Refrigerator with 2000 Watt Inverter
and (4) House Batteries (dedicated),
Stainless Steel Microwave and Oven
2014 Georgetown XL 352QS
2013-2019 Days Camped-502
chrisbailey13 is offline   Reply With Quote
fridge
