Old 12-30-2013, 03:04 AM   #1
Inline fuse for carbon monoxide detector Georgetown 374
Can anyone tell me where you would find the inline fuse for the carbon monoxide detector? Thanks
mammasueb is offline   Reply With Quote
Old 12-30-2013, 07:41 AM   #2
Did yours stop working? Not sure if it has an inline fuse or one in the fuse box. I'd start by checking the fuses in the coach's fuse box. If not, then remove the detector and check for connections.
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
alparmer is offline   Reply With Quote
Old 12-30-2013, 08:32 AM   #3
bubbles's Avatar
In my 378 it is located in the power distribution center under the steps. It is a 5amp in line fuse connected externally to one end of the control center box. I believe it is the only 5 amp fuse visible in that area.
Old 12-30-2013, 09:22 AM   #4
Thanks, have checked all fuses in coach and checked voltage at carbon monoxide detector. Did notice there was a 5amp under steps that was quite corroded, will re check
Old 01-07-2014, 07:46 PM   #5
ramair's Avatar
it is a 5amp in line fuse under the step.
Andrew & Donna Reyes
2012 Georgetown 378XL
2015 Ford Taurus
Our Baby Dachshund
Cammie
ramair is offline   Reply With Quote
Old 01-08-2014, 08:26 AM   #6
Thanks everyone - changed inline box and fuse that was under step and we now have propane. Inline fuse box was badly corroded
fuse, georgetown
