Old 05-18-2015, 05:13 PM   #1
Inside TV removal
How do you remove the tv from it mount in a 2015 Georgetown xl 378. Ned to add wireless hdmi
catellier is offline   Reply With Quote
Old 05-18-2015, 06:33 PM   #2
bubbles's Avatar
Unlike mine yours has the faux brick. There are several inputs on your dilemma. Do a forum search for them and the answer should be one of them.
Old 05-18-2015, 11:11 PM   #3
Cornelius's Avatar
Forest River uses a VESA mount behind the flat screen TV that should lift up and detach with part of the mount attached to the TV, and the other half attached to the cabinet. The problem I had with this, is that the bedroom TV mount was connected so tightly that it would not easily separate. I ended up reaching behind the TV in the cabinet and unscrewing the small piece of plywood that attached the VESA mount to the cabinet. Note that the Georgetown uses Robinson Head screws for much of the cabinetry, so you will need the correct screwdriver.
The living room TV looks like it would have to be removed the same way, as part of the cabinet fits over the top of the rear of the TV, preventing it from lifting up and off the VESA mount as it is designed to. I have not had a reason to try and remove the living room TV, but someday I might, as part of the cabinet blocks the second HDMI port on the back of the TV.
2010 Georgetown 373
2013 Jeep Wrangler
Cornelius is offline   Reply With Quote
Old 05-19-2015, 11:48 AM   #4
Catellier
Cornelius Thanks for information
Old 05-19-2015, 02:01 PM   #5
Fireman
Send a message via AIM to dutch
tv
I just remove my living room tv to hook a HDMI cable for my Tailgater. I use a extension with a #1 Robison bit and remove 6 screw on top and 4 screws on the bottom. you should be able to squeeze the extension between the tv and wood frame. You will need someone to hold the TV while you are doing that. When I screw it back on I use regular screws. Hope that helps
2013 Georgetown XL 378
Toad 2012 Honda Civic
Dutch & Kathie & shitzue Buddy
US Air Force Retire SMS
dutch is offline   Reply With Quote
Old 05-19-2015, 02:36 PM   #6
borba's Avatar
on mine the tect work on he take the fire place out in work both the out side in the inside
2015-georgetown 378xl
2013-ford fx4
2009-harley flhx
borba is offline   Reply With Quote
Old 05-19-2015, 02:54 PM   #7
thanks
